I couldn’t find a way to sort a queue by it’s type members for awhile now. This is what I’m trying to do:
typedef struct {
[63:0] bit start_addr;
[63:0] bit size;
} mem_block_t;
// Lets say this queue contains 3 values:
// start_addr = 1000, size = 200
// start_addr = 200, size = 300
// start_addr = 500, size = 100
mem_block_t mem_block[$];
// Some magical queue.sort by start_addr...
// ending queue:
Is there a way to easily do this without writing my own explicit sorting algorithm?
[EDIT1] I have written my explicit sorting algorithm for now, it isn’t actually that hard, but it would be nice if there was some kind of a short cut… Something like,
mem_block.sort with start_addr
In reply to jimmyhuang0904:
The approach is correct. One can use “with” clause to sort for individual structure elements. A sample from IEEE 1800-2017 Section 7.12 is given as below.
struct { byte red, green, blue; } c [512];
c.sort with ( item.red ); // sort c using the red field only
c.sort( x ) with ( {x.blue, x.green} ); // sort by blue then green
Using the same above strategy, the following code should sort by start_addr:
module top();
typedef struct {
bit [63:0] start_addr;
bit [63:0] sizee;
} mem_block_t;
// ending queue:
mem_block.push_back('{700,200});
mem_block.push_back('{1000,800});
mem_block.push_back('{500,300});
mem_block.sort(item) with (item.start_addr);
//mem_block.sort(item) with (item.sizee); // one can sort by size also
foreach(mem_block[i]) begin
$write("mem_block[%0d].start_addr = %0d",i,mem_block[i].start_addr);
$write("mem_block[%0d].sizee = %0d",i,mem_block[i].sizee);
$display();
// output:
mem_block[0].start_addr = 500mem_block[0].sizee = 300
mem_block[1].start_addr = 700mem_block[1].sizee = 200
mem_block[2].start_addr = 1000mem_block[2].sizee = 800
In reply to sharvil111:
Wow That is exactly what I wanted!! I didn’t realize I need the item keyword (saw some examples without it).
Thanks! Replaced like 10 lines of ugly code with 1 elegant one
