Hi everybody,
I was reading thorugh a paper on Soft Constraints in SystemVerilog, and this was what the PDF has said about the priorities of soft constraints:
Mantis 2987 proposal [3] to SV-EC IEEE 1800 committee defines the priorities of soft constraints:
- Constraint expressions that appear later in the same construct (constraint block, class, or struct) have
higher priority. - Constraint expressions in out-of-body constraint blocks whose prototypes appear later in the class have
higher priority. - Constraints in contained objects (rand class handles) have lower priority than all constraints in the container object (class or struct).
- Constraints in objects whose handles appear later in the container object have higher priority
- Constraints in derived classes have higher priority than all constraints in their super classes
- Constraints within inline constraint blocks have higher priority than constraints in the class being randomized.
- Latter iterations within a foreach constraint have higher priority than former iterations
Based on these set of definitions, I have tried to understand the following lines of code:
According to the author of the guide, it is said the the following is the priority order:
Can someone define or summarize which rule has the highest priority of soft constraints?
Also, what is p3.a2, p3.a1, p2.a2, etc represent?
Thank you!
Sangwoo
