Which part of the test-bench consumes more simulation time?
Thanks in advance.
Thanks in advance.
In reply to kireeti1192:
There is nmo more or less. Only the run_phase and the sub_phases like main_phase are consuming time. All other phases are functions and will be executed in 0 time.
Thanks in advance.
I think you need too explain your question better. What “parts” are you thinking about? And what do you mean by “consume more”?
Sorry Dave.
For example, in a Scoreboard we can use analysis fifos or Queues to store the transactions. Will the simulation time remain constant if I use anyone of these.
How you choose to store transactions has nothing to do with simulation time. The call to analysis_port.write() function in your monitor determines when the transaction is sent to the scoreboard.
