Dear experts,
I am looking for some information and associated guidelines regarding the use of SystemVerilog data-types to optimize the simulation speed and memory footprint with Questa, especially in the context of UVM classes (sequence items, components, etc).
Regarding the 2-state logic data-types, SV provides bit, byte, shortint, int and longint. Am I right to assume that SV data-types may not be equivalent in terms of simulation speed and memory footprint?
Booleans/Binary decisions:
They can be encoded in a single bit. In C, the result of a boolean operation is commonly encoded as an int data-type. In SV with Questa, is there any speed/memory benefit or penalty of using the bit data-type instead of the int data-type (or any other data-type) to store the result of boolean operations?
Packed bits vs. byte/shortint/int/longint data-types:
For instance a quartet can be declared as bit [3:0] or stored in a larger standard SV data-type, byte, shortint, int, longint. Regarding performance of packed-bits versus standard SV data-types, I guess the answer to the simulation speed depends on the operations performed on this variable. However if there is no significant difference between packed bits and standard data-types in terms of memory footprint and simulation speed, it might be easier to use packed bits. If there is a noticeable difference, it might be preferable to use standard SV data-types and mask the unused bits whenever necessary. Do we have an evaluation of the speed/memory benefit or penalty of using a packed-bits rather than a standard data-type?
Byte vs shortint vs int vs longint data-types:
While the number of bits required for each data-type differ, is there a significant difference in terms of memory footprint and simulation speed between these 4 SV data-types with Questa on current Intel processors (linux x64)?
For instance, is the simulation faster when accessing/manipulating members of int data-type rather than of other data-types?
Do we always observe a memory footprint proportional to the number of bits corresponding to the size of the standard data-type (4 data-members of int data-type would always require 4 times the memory of 4 data-member of byte data-type)?
Can the relative performance of bits, packed-bits, byte, shortint, int and longint be considered as similar in case of data-members of classes and in case of variables/arguments of functions and tasks?
PS: On 2-state versus 4-state logic data-types, I assume that 2-state logic simulates faster than 4-state logic, leading to the underlying rule: preferably use 2-state logic unless 4-state logic is required.
