pepes
May 7, 2019, 9:34am
1
Is there an easy way to connect the DUT with interface?
for example, implicit connection like .*, but I don’t see how it works here.
my_ifc ifc;
//TO CONNECT IFC TO DUT
//usually we do this..
my_dut dut(.a(ifc.a),.b(ifc.b));
//is there a way to do something like this
my_dut dut(.*);
interface my_ifc;
logic a;
logic b;
endinterface
module my_dut;
input a;
output b;
// codes
In reply to pepes :
The wildcard named port connections (.*) requires that the port name and data types are equivalent, so you can’t use an interface in this manner.
However, you can use an interface as a module port.
interface simple_bus(input logic clk); // Define the interface
logic req, gnt;
logic [7:0] addr, data;
logic [1:0] mode;
logic start, rdy;
endinterface: simple_bus
module memMod(simple_bus a); // simple_bus interface port
logic avail;
// When memMod is instantiated in module top, a.req is the req
// signal in the sb_intf instance of the 'simple_bus' interface
always @(posedge a.clk) a.gnt <= a.req & avail;
module cpuMod(simple_bus b); // simple_bus interface port
logic clk = 0;
simple_bus sb_intf(.clk(clk)); // Instantiate the interface
memMod mem(.a(sb_intf)); // Connect interface to module instance
cpuMod cpu(.b(sb_intf)); // Connect interface to module instance
