Hello…I am a kind of stuck in concept regarding shallow copy while working on the following piece of code…
Actually…as far as i know, in case of shallow copy, only pointers are copied, like let us suppose, we are having A class B having handle b1 i.e. pointing to some memory (in which variable value is stored), now we are having b2 as shallow copy of b1; so if we’ll access variable “i” through handle b2 and give it some another value, then variable “i” value will be overwritten, so if we’ll display both b1.i and b2.i, then it should give us new overwritten value…but its not happening in following case…
Example1:
class B;
int i;
program main;
initial
B b1;
B b2;
b1 = new();
b1.i = 123;
b2 = new b1;
b2.i = 321;
$display( b1.i );
$display( b2.i );
endprogram
Result
123
321
Although, if we’ll try the below given example, then we’ll get the overwritten results as it should be in shallow copy.
example 2::
class A;
int i;
class B;
A a;
program main;
initial
B b1;
B b2;
b1 = new();
b1.a = new();
b1.a.i = 123;
b2 = new b1;
$display( b1.a.i );
$display( b2.a.i );
b1.a.i = 321;
$display( b1.a.i );
$display( b2.a.i );
endprogram
RESULT
123
123
321
321
Could someone please explain me that why is there difference in overwriting in both the cases of shallow copy?
Thanks in advance!!
