I understand how severity action works. But now I want to convert severity level from error to info,then what should be the change in this program ? Where the modification requires ?
import uvm_pkg::*;
class rpting extends uvm_component;
int d=2;
`uvm_component_utils(rpting)
function new(string name,uvm_component parent);
super.new(name, parent);
super.build_phase(phase);
`uvm_info("BUILD", $sformatf("%m"), UVM_HIGH);
endfunction: build_phase
virtual function void connect_phase(uvm_phase phase);
super.connect_phase(phase);
`uvm_info("CONNECT", $sformatf("%m"), UVM_HIGH);
endfunction: connect_phase
virtual function void start_of_simulation_phase (uvm_phase phase);
set_report_severity_id_action(UVM_ERROR, "ERROR", UVM_EXIT);
endfunction: start_of_simulation_phase
task run();
$display("-------------------------------------------------------------");
if(d==2) begin
`uvm_error("ERROR", "Failed");
uvm_report_info(get_full_name(),"Info Message : Verbo lvl - UVM_NONE ",UVM_NONE,`__FILE__,`__LINE__);
rpting rpt1;
rpting rpt2;
rpting rpt3;
rpt1 = new("rpt1",null);
rpt2 = new("rpt2",null);
rpt3 = new("rpt3",null);
run_test();
