Setting multiple config_db for an interface?
interface dut_if#(parameter L_DSP = `define_l);
// signals
endinterface
module tb;
generate
for(genvar i =0; i < L_DSP; i++ ) begin
   //dut_if#(L_DSP[i]) u_dut_if();
   dut_if u_dut_if();
      uvm_config_db#(virtual dut_if#(L_DSP))::set(null,"*",$sformatf("u_dut_if_%0d", i),u_dut_if);
      //uvm_config_db#(virtual dut_if#(L_DSP[i]))::set(null,"*",$sformatf("u_dut_if_%0d", i),u_dut_if[i]);
endgenerate
class my_com extends uvm_component;
     super.build_phase(phase);
     if (!uvm_config_db #(virtual dut_if )::get(null, "", "u_dut_if ", u_dut_if)) begin
         `uvm_error("NOVIF", {"virtual interface not configured for ", get_full_name(), "u_dut_if "})
for the commented:
//error: Bit-select or part-select dimensions do not match declaration****
for uncommented:
// error from class my_com : `uvm_error(“NOVIF”, {"virtual interface not configured for ", get_full_name(), "u_dut_if "})
In reply to muku_383:
What do you mean by “not working”? Compilation error? Run-time error?
It would be helpful if you post a complete example which demonstrates your error.
In reply to cgales:
updated
When you have a parameterized interface, you need to ensure that the you use the same parameters in the set() and get() calls. In your case, you have a parameter in the set() call, but the get() has no parameter. This will result in not being able to find a compatible value.
