Setting environment variables in SystemVerilog
I am launching a simulation that is managed through a TCL script. The TCL script implements a while loop and in each loop a simulation is invoked.
TCL Script:
while {some_condition} {
    #some logic here
    run_simulation
    set env_var_a $::env(VAR_A)
    set env_var_b $::env(VAR_B)
    reset_simulation
    #rinse and repeat
Now in my SystemVerilog, right before the stop statement of the testbench I do the following
     setenv("VAR_A", $sformatf("%0f", result_a), 1);
     setenv("VAR_B", $sformatf("%0f", result_b), 1);
I have imported the DPI-C setenv function as
import "DPI-C" function int setenv(string name, string value, int override);
But the changes are not reflected back to the TCL script i.e., the VAR_A, and VAR_B variables are not modified.
What is the problem here?
Are the environment variables shallow-copies? In that case it makes sense that a parental process is not aware of any changes done by a child process.
Thank you in advance
In reply to Broxigar:
I think you answered your own question.
