In reply to Edison_yu:
class jelly_bean_taste_reg extends uvm_reg;
`uvm_object_utils( jelly_bean_taste_reg )
rand uvm_reg_field taste;
function new( string name = "jelly_bean_taste_reg" );
super.new( .name( name ), .n_bits( 2 ), .has_coverage( UVM_NO_COVERAGE ) );
endfunction: new
virtual function void build();
taste = uvm_reg_field::type_id::create("taste");
taste.configure( .parent ( this ),
.size ( 2 ),
.lsb_pos ( 0 ),
.access ( "RO" ),
.volatile ( 1 ),
.reset ( 0 ),
.has_reset ( 1 ),
.is_rand ( 1 ),
.individually_accessible( 1 ) );
endfunction: build
endclass: jelly_bean_taste_reg
If you want to change the endianness while writing into the register then you need to change the lsb_pos like above mention code. Suppose your register size is 8 and you want to write as bigendian then you can give .lsb_pos as 7. Then your 7th position bit will be written in register’s 0th location.
