Setting a string/int inside uvm_object using UVM command line processor method
class top_env extends uvm_env;
     // UVM Component Utility macro
        `uvm_component_utils_begin(top_env)
         `uvm_field_object(cfg, UVM_ALL_ON)
        `uvm_component_utils_end
     // SOC System Configuration
        configuration_obj cfg;
endclass: top_env
class configuration_obj extends uvm_object;
   `uvm_object_utils_begin (configuration_obj)
     `uvm_field_string(temp_name, UVM_ALL_ON)
   `uvm_object_utils_end
   string temp_name;
   /** Constructor */
   function new (string name = "configuration_obj");
     super.new(name);
 endclass: configuration_obj
In the above code I want to set the value of temp_name string using command line processor method. Is there any way I can set this value? I tried the following methods but nothing is helping me.
+uvm_set_config_string=uvm_test_top.top_uvm_env.cfg,temp_name,SAURABH
+uvm_set_config_string=uvm_test_top.top_uvm_env..*,temp_name,SAURABH
+uvm_set_config_string=uvm_test_top.top_uvm_env.*,temp_name,SAURABH
Saurabh
In reply to saurabh.sa27:
The string type in your config object is called name and not temp_name.
I did a typo while typing the code here. Thanks for pointing the mistake.
But the mistake is still there?
I made mistake while pasting code here. I checked my local code it doesn’t have the typo.
Still looking for the solution.
-Saurabh
You have to provide a string from the commandline like this:
+uvm_set_config_string=uvm_test_top.top_uvm_env.\*,temp_name, "SAURABH"
@chr_sue, I don’t think it will work, the commandline uvm_set_config_string need the arguments:
+uvm_set_config_string=<comp>,<field>,<value>
The first argument needs to be uvm_component, can’t be an uvm_object.
Since the “cfg” class in top_env class is an object, then I don’t think we can use +uvm_set_config_string to set value to cfg directly.
