class A #(type T=uvm_transaction) extends B
`uvm_object_param_utils( A#(T) ) //Also tried with `uvm_object_utils()
class B #(type T=uvm_transaction) extends C
`uvm_object_param_utils( B#(T) ) //Also tried with `uvm_object_utils()
class C #(type T=uvm_transaction) extends uvm_sequence
`uvm_object_utils( C#(T) )
I am using plusargs to override
+uvm_set_type_override=C,A
But I am running intho this error
UVM_ERROR @ 0: reporter [TYPNTF] Cannot register override for original type ‘C’ because the override type ‘A’ is not registered with the factory.
You can’t override parameterized types from the command line. You may be able to create specialized types with typedefs and use them in an override, but I’ve never tried.
