Sequencer to sum up two sequences
my intention is to build an agent that emulates the movement of an object in x,y coordinates using goto commands.
  • the movement is not active at all times
  • a noise (sinusoidal, 10-20KHz) must also be generated at all times (independent of movement status)
  • position items generated continuously at a fixed rate
My plan is:
  • one sequence for movement items (x,y points), started when goto command called and running until destination reached
  • one sequence for noise (x,y points) started when running_phase is called
The driver should sum noise + movement (if active) and send the resulting (x,y) to the bus.
How can I implement the sequence summation? Can one implement an intermediate sequencer?
I was able to do it by implementing:
