Sequence start/start_item
Sorry if this is a very basic question.
Please look at the following code that I am referring to:
class one_jelly_bean_sequence extends uvm_sequence#(jelly_bean_transaction);
   `uvm_object_utils(one_jelly_bean_sequence)
   function new(string name = "");
      super.new(name);
   endfunction: new
   task body();
      jelly_bean_transaction jb_tx;
      jb_tx = jelly_bean_transaction::type_id::create(.name("jb_tx"), .contxt(get_full_name()));
      start_item(jb_tx);
      assert(jb_tx.randomize());
      finish_item(jb_tx);
   endtask: body
endclass: one_jelly_bean_sequence
class gift_boxed_jelly_beans_sequence extends uvm_sequence#(jelly_bean_transaction);
   rand int unsigned num_jelly_bean_flavors; // knob
   constraint num_jelly_bean_flavors_con { num_jelly_bean_flavors inside { [2:3] }; }
      super.new(name);
   endfunction: new
   task body();
      same_flavored_jelly_beans_sequence jb_seq;
      repeat (num_jelly_bean_flavors) begin
         jb_seq = same_flavored_jelly_beans_sequence::type_id::create(.name("jb_seq"), .contxt(get_full_name()));
         assert(jb_seq.randomize());
         jb_seq.start(.sequencer(m_sequencer), .parent_sequence(this));
   endtask: body
   `uvm_object_utils_begin(gift_boxed_jelly_beans_sequence)
      `uvm_field_int(num_jelly_bean_flavors, UVM_ALL_ON)
   `uvm_object_utils_end
endclass: gift_boxed_jelly_beans_sequence
I am not quite clear what is the difference between start_item and start used in the first and the second example.
Also, in case of start_item, I am not clear why reference to sequencer is not passed
PS: code reference
UVM Tutorial for Candy Lovers – 3. Transactions and Sequences – ClueLogic
In reply to verif_learner:
start_item() is a method of an already running sequence - the sequencer was set when you started it. start_item/finish_item is used to send transactions to a driver, and thus must be connected to a sequencer.
start() is a method of a sequence object you just created, and in turn calls its body() method. You pass in a sequencer to the start() method if you want the sequence body to call the start_item() method.
