My intent is to create several testpoints for crossing scenarios when events A, B, C… happen simultaneously.
My code:
sequence A(signal, event);
@(posedge event)
(signal == 1'b1);
endsequence
sequence B(fmt,event);
@(posedge event)
(fmt==4'd5);
endsequence
property is_A_and_B(integer win);
@(posedge clk)
(A(bus1[win], bus2[win]) && B(bus3[win], bus2[win]));
everything: cover property(is_A_and_B(3));
I’m getting this error in VCS:
Error-[SPIUNTC] Instance used in non-temporal context
can someone please explain what the issue is and what is a good way to achieve the intent?
In reply to mzamek2:
- Your requirements are not clear.
- The error message is because you are using the wrong sequence ANDing operator.
- - && is a logical AND.
- and is a sequence AND
thus (a ##1 b) and (c ##[1:3] d)
- In “sequence A(signal, event);”, event is a type and not an argument.
You can do sequence A(signal, event e);
- Your property definition is very unusual as you are using the clocking event as the leading clocking event (OK, should be like this), BUT then in “B(bus3[win], bus2[win])” you use a sequence as a clocking event. This is not how things are done typically.
Sequences can be used as clocking event, but they are rarely used as such. Below is code that simulates, though i am not much of a proponent of using sequences as clocking events; I never do that, but I address it in my SVA book.
timeunit 1ns; timeprecision 100ps;
bit clk, a, b, c;
default clocking @(posedge clk);
endclocking
initial forever #10 clk=!clk;
sequence q1;
@(posedge clk) a ##1 b;
endsequence
always begin
@(q1) if(c!=1'b1) $display("%t error, c!=1", $realtime);
ap_q1c: assert property(@(q1) c); // Unusal usage of sequence as clocking event
// typical usage: @(posedge clk) q1 ##0 c; //
// Better usage: @(posedge clk) q1 |-> c; //
repeat(200) begin
@(posedge clk); #2;
if (!randomize(a, b, c) with
{ a dist {1'b1:=1, 1'b0:=3};
b dist {1'b1:=1, 1'b0:=2};
c dist {1'b1:=1, 1'b0:=1};
$stop;
See Paper: VF Horizons:PAPER: SVA Alternative for Complex Assertions | Verification Academy
