Send_request failed to cast sequence item
there are many means to solve this question in forum, but i dont find the answer suit for me! below is my code :
class ahbl_trans extends uvm_sequence_item;
rand logic hsel;
rand logic [31:0] haddr = 32’b0;
rand htrans_t htrans = NSEQ;
rand hsize_t hsize = BYTE;
rand hburst_t hburst = WRAP4;
rand logic [3:0] hprot = 4’b0;
rand logic hwrite = 1’b0;
rand logic [31:0] hrwdata = 32’b0;
rand logic hresp = 1’b0;
rand logic hreadyout = 1’b1;
rand logic		[3:0]	clk_ratio = 4'h1;
protected rand int unsigned	bst_beats;
protected rand logic [31:0] haddr_q[$];
protected rand logic [31:0] hrwdata_q[$];
protected rand htrans_t		htrans_q[$];
protected int unsigned		haddr_idx	=	0;
protected int unsigned		hrwdata_idx = 	0;
protected int unsigned		htrans_idx	= 	0;
//Factory Registration
`uvm_object_utils_begin(ahbl_trans)
	`uvm_field_int			(hsel,				UVM_ALL_ON)
	`uvm_field_int			(haddr, 			UVM_ALL_ON)
	`uvm_field_enum			(htrans_t,	htrans, UVM_ALL_ON)
	`uvm_field_enum			(hsize_t,	hsize, 	UVM_ALL_ON)
	`uvm_field_enum			(hburst_t,	hburst, UVM_ALL_ON)
	`uvm_field_int			(hprot, 			UVM_ALL_ON)
	`uvm_field_int			(hwrite, 			UVM_ALL_ON)
	`uvm_field_int			(hrwdata, 			UVM_ALL_ON)
	`uvm_field_int			(hreadyout,			UVM_ALL_ON)
	`uvm_field_int			(clk_ratio,			UVM_ALL_ON)
	`uvm_field_int			(hresp,				UVM_ALL_ON)
	`uvm_field_int			(bst_beats,	      	UVM_ALL_ON)
	`uvm_field_queue_int	(haddr_q,          	UVM_ALL_ON)
	`uvm_field_queue_int	(hrwdata_q,        	UVM_ALL_ON)
	`uvm_field_queue_enum	(htrans_t,	htrans_q,         	UVM_ALL_ON)
	`uvm_field_int			(haddr_idx,	      	UVM_ALL_ON)
	`uvm_field_int			(hrwdata_idx,      	UVM_ALL_ON)
	`uvm_field_int			(htrans_idx,      	UVM_ALL_ON)
`uvm_object_utils_end
// Constraints
constraint haddr_constr{
	(hsize == HWORD)-> (haddr[0] == 1'b0);
	(hsize == WORD)	-> (haddr[1:0] == 2'b0);
	solve hsize before haddr;
constraint hsize_constr{
	(hsize <= 2);	//Bit-width == 32, so hsize == BYTE/HWORD/WORD
constraint htrans_constr{
	htrans == IDLE -> (hburst == SINGLE);
	solve htrans before hburst;
constraint hburst_constr{
	(hburst == SINGLE) -> (bst_beats == 1);
	(hburst == WRAP4 ) -> (bst_beats == 4);
	(hburst == WRAP8 ) -> (bst_beats == 8);
	(hburst == WRAP16) -> (bst_beats == 16);
	(hburst == INCR4 ) -> (bst_beats == 4);
	(hburst == INCR8 ) -> (bst_beats == 8);
	(hburst == INCR16) -> (bst_beats == 16);
	solve hburst before bst_beats;
constraint queue_constr{
	haddr_q.size() 		== bst_beats;
	hrwdata_q.size() 	== bst_beats;
	htrans_q.size() 	== bst_beats;
	solve bst_beats before haddr_q;
	solve bst_beats before hrwdata_q;
	solve bst_beats before htrans_q;
logic [3:0] array_ratio[] ='{4'h1,4'h2,4'h4,4'h8};
constraint clk_ratio_constr{
	clk_ratio inside {array_ratio};
// Methods
// Standard UVM Methods:
function new(string name = "ahbl_tran");
	super.new(name);
	int i;
	haddr_q[0] 		= haddr;
	htrans_q[0]		= NSEQ;
	hrwdata_q[0] 	= hrwdata;
	for (i = 1; i < bst_beats; i++) begin
		haddr_q[i] 	= haddr_q[i-1] + (2**hsize);
		htrans_q[i]	= SEQ;
// User Defined Methods:
virtual function logic [31:0] nxt_haddr();
	haddr_idx++;
	return haddr_q[haddr_idx - 1];
virtual function logic [31:0] nxt_hrwdata();
	hrwdata_idx++;
	return hrwdata_q[hrwdata_idx - 1];
virtual function logic [31:0] nxt_htrans();
	htrans_idx++;
	return htrans_q[htrans_idx - 1];
virtual function logic [31:0] htrans_ro();
	htrans_ro = htrans_q[htrans_idx];
	return htrans_ro;
virtual function bit last_beat();
	return (htrans_idx == htrans_q.size());
virtual function int get_bst_beats();
	return(bst_beats);
class ahbl_mst_basic_seq extends uvm_sequence#(ahbl_trans);
ahbl_trans req;
`uvm_object_utils(ahbl_mst_basic_seq)
// Methods
function new(string name = "ahbl_mst_basic_seq");
	super.new(name);
virtual task pre_body();
	if(starting_phase != null) begin
		starting_phase.raise_objection(this);
virtual task post_body();
		starting_phase.drop_objection(this);
class ahbl_mst_burst_seq extends ahbl_mst_basic_seq;
`uvm_object_utils(ahbl_mst_burst_seq)
// Methods
function new(string name = "ahbl_mst_burst_seq");
	super.new(name);
/*virtual task body();
	ahbl_trans req;
	`uvm_do_with(req, {	req.hsel == 1'b1; req.hburst inside {[2:7]};})
endtask*/
	req = ahbl_trans::type_id::create("req");
	`uvm_info(get_type_name(),"create complete",UVM_LOW)
	wait_for_grant();
	`uvm_info(get_type_name(),"GET GRANT",UVM_LOW)
	assert(req.randomize() with {	req.hsel == 1'b1; req.hburst inside {[2:7]};});
	`uvm_info(get_type_name(),"RANDOMIZE SUCCESSFUL",UVM_LOW)
	req.print();
	send_request(req);
	`uvm_info(get_type_name(),"SEND REQUEST",UVM_LOW)
	wait_for_item_done();
	get_response(rsp);
class ahbl_mst_sqr extends uvm_sequencer#(ahbl_trans);
`uvm_component_utils(ahbl_mst_sqr)
// Methods
extern function new(string name = "ahbl_mst_sqr", uvm_component parent);
extern virtual function void build_phase(uvm_phase phase);
//Constructor
function ahbl_mst_sqr::new(string name = “ahbl_mst_sqr”, uvm_component parent);
super.new(name, parent);
function void ahbl_mst_sqr::build_phase(uvm_phase phase);
super.build_phase(phase);
class ahbl_mst_drv extends uvm_driver#(ahbl_trans);
// Data, Interface, port  Members
virtual ahbl_if vif;
 ahbl_trans pkt_apha = null;		//packet address-phase
 ahbl_trans pkt_dpha = null;		//packet data-phase
uvm_sequence_item item;
`uvm_component_utils(ahbl_mst_drv)
// Methods
extern function new(string name = "ahbl_mst_drv", uvm_component parent);
extern virtual task main_phase(uvm_phase phase);
extern task drive_lcyc_pkt_dpha(ref ahbl_trans pkt);
extern task drive_lcyc_pkt_apha(ref ahbl_trans pkt);
extern task drive_lcyc_pkt_idle();
class ahbl_mst_tight_transfer extends ahb2apb_base_test;
ahbl_mst_burst_seq		ahbl_mst_burst_seq_0;
ahbl_mst_burst_seq		ahbl_mst_burst_seq_1;
apb_slv_nrdy_seq		apb_slv_nrdy_seq_i;
`uvm_component_utils(ahbl_mst_tight_transfer)
// Methods
extern function new(string name = "ahbl_mst_tight_transfer", uvm_component parent);
//Constructor
function ahbl_mst_tight_transfer::new(string name = “ahbl_mst_tight_transfer”, uvm_component parent);
//Build_Phase
function void ahbl_mst_tight_transfer::build_phase(uvm_phase phase);
ahbl_mst_burst_seq_0 = ahbl_mst_burst_seq::type_id::create(“ahbl_mst_burst_seq_0”);
ahbl_mst_burst_seq_1 = ahbl_mst_burst_seq::type_id::create(“ahbl_mst_burst_seq_1”);
apb_slv_nrdy_seq_i = apb_slv_nrdy_seq::type_id::create(“apb_slv_nrdy_seq_i”);
//Main_Phase
task ahbl_mst_tight_transfer::main_phase(uvm_phase phase);
int num_apb_seq;
super.main_phase(phase);
#100us;
		ahbl_mst_burst_seq_0.start(env_i.ahbl_mst_agt_i.sqr_i);
		ahbl_mst_burst_seq_1.start(env_i.ahbl_mst_agt_i.sqr_i);
		num_apb_seq = 0;
		while(1) begin
			apb_slv_nrdy_seq_i.start(env_i.apb_slv_agt_i.sqr_i);
			num_apb_seq++;
			if(num_apb_seq >= ahbl_mst_burst_seq_0.req.get_bst_beats()) begin
				num_apb_seq = 0;
				break;
		while(1) begin
			num_apb_seq++;
			if(num_apb_seq >= ahbl_mst_burst_seq_1.req.get_bst_beats())
				break;
join
//Constructor
function ahbl_mst_drv::new(string name = “ahbl_mst_drv”, uvm_component parent);
//Build_Phase
function void ahbl_mst_drv::build_phase(uvm_phase phase);
if(!uvm_config_db#(virtual ahbl_if)::get(this,“”,“vif”,vif))
`uvm_fatal(“my_driver”, “Error in Getting interface”)
//Main_Phase
task ahbl_mst_drv::main_phase(uvm_phase phase);
while(1) begin
@(vif.mst_cb);
if(!vif.mst_cb.hresetn) begin
vif.mst_cb.hsel <= 1’b0;
vif.mst_cb.haddr <= 32’b0;
vif.mst_cb.htrans <= IDLE;
vif.mst_cb.hsize <= BYTE;
vif.mst_cb.hburst <= SINGLE;
vif.mst_cb.hprot <= 4’b0;
vif.mst_cb.hwrite <= 1’b0;
vif.mst_cb.hwdata <= 32’b0;
vif.mst_cb.clk_ratio<= 4’h1;
pkt_dpha = null;
pkt_apha = null;
else begin
//transfer data
if(pkt_dpha != null) begin
drive_lcyc_pkt_dpha(pkt_dpha);
if(vif.mst_cb.hready & (pkt_dpha.hburst == SINGLE | pkt_dpha.last_beat())) begin
seq_item_port.item_done();
pkt_dpha = null;
pkt_apha = null;
		if(pkt_apha != null) begin
		//transfer address
			drive_lcyc_pkt_apha(pkt_apha);
		else begin
			`uvm_info(get_type_name(),"BEFORE get next item",UVM_LOW)
			seq_item_port.get_next_item(pkt_apha);//(pkt_apha);
			`uvm_info(get_type_name(),"AFTER get next item",UVM_LOW)
				pkt_apha.print();
				`uvm_info(get_type_name(), "ahbl_mst_drv successfully get a new AddressPhase pkt", UVM_LOW)
			else begin
				//`uvm_info(get_type_name(), "ahbl_mst_drv didn't get a new AddressPhase pkt", UVM_LOW)
task ahbl_mst_drv::drive_lcyc_pkt_dpha(ref ahbl_trans pkt);
if(vif.mst_cb.hready)
vif.mst_cb.hwdata <= pkt.hwrite ? pkt.nxt_hrwdata() : 32’d0;
task ahbl_mst_drv::drive_lcyc_pkt_apha(ref ahbl_trans pkt);
if((vif.mst_cb.hready)) begin
vif.mst_cb.hsel <= pkt.hsel;
vif.mst_cb.haddr <= ((pkt.htrans_ro() != IDLE)&(pkt.htrans_ro() != BUSY)) ? pkt.nxt_haddr() : vif.haddr;
vif.mst_cb.htrans <= pkt.nxt_htrans();
vif.mst_cb.hsize <= pkt.hsize;
vif.mst_cb.hburst <= pkt.hburst;
vif.mst_cb.hprot <= pkt.hprot;
vif.mst_cb.hwrite <= pkt.hwrite;
vif.mst_cb.clk_ratio<= pkt.clk_ratio;
this.pkt_dpha <= this.pkt_apha;
task ahbl_mst_drv::drive_lcyc_pkt_idle();
UVM_INFO .\dv\vip\ahbl_mst\ahbl_mst_drv.svh(98) @ 50: uvm_test_top.env_i.ahbl_mst_agt_i.drv_i [ahbl_mst_drv] BEFORE get next item
UVM_INFO ./dv/seqlib/ahbl_mst_seqlib.sv(75) @ 100007: uvm_test_top.env_i.ahbl_mst_agt_i.sqr_i@@ahbl_mst_burst_seq_0 [ahbl_mst_burst_seq] create complete
UVM_INFO ./dv/seqlib/ahbl_mst_seqlib.sv(77) @ 100007: uvm_test_top.env_i.ahbl_mst_agt_i.sqr_i@@ahbl_mst_burst_seq_0 [ahbl_mst_burst_seq] GET GRANT
UVM_INFO ./dv/seqlib/ahbl_mst_seqlib.sv(79) @ 100007: uvm_test_top.env_i.ahbl_mst_agt_i.sqr_i@@ahbl_mst_burst_seq_0 [ahbl_mst_burst_seq] RANDOMIZE SUCCESSFUL
Name Type Size Value
req ahbl_trans - @1023
hsel integral 1 'h1
haddr integral 32 'hf04b3dfc
htrans htrans_t 2 SEQ
hsize hsize_t 3 HWORD
hburst hburst_t 3 INCR16
hprot integral 4 'h4
hwrite integral 1 'h1
hrwdata integral 32 'h87757203
hreadyout integral 1 'h0
clk_ratio integral 4 'h4
hresp integral 1 'h0
bst_beats integral 32 'h10
haddr_q da(integral) 16 -
[0] integral 32 'hf04b3dfc
[1] integral 32 'hf04b3dfe
[2] integral 32 'hf04b3e00
[3] integral 32 'hf04b3e02
[4] integral 32 'hf04b3e04
[11] integral 32 'hf04b3e12
[12] integral 32 'hf04b3e14
[13] integral 32 'hf04b3e16
[14] integral 32 'hf04b3e18
[15] integral 32 'hf04b3e1a
hrwdata_q da(integral) 16 -
[0] integral 32 'h87757203
[1] integral 32 'hc465ecd5
[2] integral 32 'hfb163a14
[3] integral 32 'hd767f58d
[4] integral 32 'h3444859
[11] integral 32 'h43b60bde
[12] integral 32 'h6599fa67
[13] integral 32 'h79662df7
[14] integral 32 'hf182cf2
[15] integral 32 'hfc82bda1
htrans_q array(htrans_t) 16 -
[0] htrans_t 2 NSEQ
[1] htrans_t 2 SEQ
[2] htrans_t 2 SEQ
[3] htrans_t 2 SEQ
[4] htrans_t 2 SEQ
[11] htrans_t 2 SEQ
[12] htrans_t 2 SEQ
[13] htrans_t 2 SEQ
[14] htrans_t 2 SEQ
[15] htrans_t 2 SEQ
haddr_idx integral 32 'h0
hrwdata_idx integral 32 'h0
htrans_idx integral 32 'h0
UVM_FATAL @ 100007: uvm_test_top.env_i.ahbl_mst_agt_i.sqr_i [sqr_i] send_request failed to cast sequence item
from the simulation information i know the mistake maybe is around get_next_item(),but i dont know how to fix it.
In reply to blizzard:
How have you declared sequence apb_slv_nrdy_seq ? .
I suspect that it isn’t parameterized to type ahbl_trans unlike sequence ahbl_mst_basic_seq N ahbl_mst_burst_seq
In reply to ABD_91:
In class ahbl_mst_burst_seq rsp is not declared. You have only decared req.
Calling get_response(rsp) results in an error.
Via virtual class uvm_sequence I believe the extended classes inherit the following ::
  REQ  req ;
  RSP  rsp ;
’ rsp ’ handle can be directly used in get_response
For ’ req ’ user can directly call ::
 req = REQ :: type_id :: create( "req" , .. ) ;
Followed by ::
start_item( req ) ;
if( ! req.randomize() ) // Although ' req '  isn't  rand type , Randomization  called  !!
  `uvm_error( .. )
 finish_item( req ) ;
In reply to ABD_91:
I agree.
In reply to ABD_91:
what i want to verify is a module of ahb to apb bridge, so the master and the slave will send the different transaction.below is the declare of apb_slv_nrdy_seq,
class apb_slv_basic_seq extends uvm_sequence #(apb_trans);
apb_trans req;
`uvm_object_utils(apb_slv_basic_seq)
// Methods
function new(string name = "apb_slv_basic_seq");
	super.new(name);
class apb_slv_nrdy_seq extends apb_slv_basic_seq;
`uvm_object_utils(apb_slv_nrdy_seq)
// Methods
function new(string name = "apb_slv_nrdy_seq");
	super.new(name);
	`uvm_do_with(req, {	pslverr		== 1'b0;
						nready_num 	inside {[1:5]};})
i run the program and i find the step of get_next_item()failed, so the driver dont get to the step of put response to the sequence.
This is the cause of the error ::
class apb_slv_basic_seq extends uvm_sequence #(apb_trans);  // Should be  :: #(ahbl_trans)
whereas your sequencer is declared as ::
class ahbl_mst_sqr extends uvm_sequencer#(ahbl_trans) ;
I assume the handle of type ’ sqr_i ’ is of type ’ ahbl_mst_sqr ’
Also as a suggestion if you could share EDA link of your working code it would be easier to debug .
I would suggest to declare a base class and use it during Specialization of the
user_sequence , sequencer and driver classes .
Class ’ ahbl_trans ’ and ’ apb_trans ’ would extend this base class .
In reply to ABD_91:
could i email you my code ?thank you very much.i dont know how to share eda link.
By EDA link I mean to register on EDAPlayground
Once registered simply paste your code in there and share the link for the code .
In reply to ABD_91:
hello, here is my EDA share link, thank for your help!
Thanks for sharing your code. But there are a lot of weaknesses inside.
Your problem might arise from this Warnings:
UVM_WARNING @ 0: reporter [TPRGED] Type name ‘ahbl_trans’ already registered with factory. No string-based lookup support for multiple types with the same type name.
UVM_WARNING @ 0: reporter [TPRGED] Type name ‘apb_trans’ already registered with factory. No string-based lookup support for multiple types with the same type name.
It seems you are registering the same transaction type more than once. But I did not find the places.
See here the running version
Thanks a lot for your help! The error come from package all , the ahbl_mst_pkg package and apb_slv_pkg package already contain the ahbl_trans.svh and apb_trans.svh respectively,but i include they once agin in the all package .
package all;
import uvm_pkg::;
`include “uvm_macros.svh”
**import ahbl_mst_pkg::
import apb_slv_pkg::;**
import ahb2apb_pkg::
`include "ahb2apb_base_test.sv"
**//`include "ahbl_trans.svh"
//`include "apb_trans.svh"**
`include "ahbl_mst_seqlib.sv"
`include "apb_slv_seqlib.sv"
`include "ahbl_mst_burst_apb_slv_slverr.sv"
`include "ahbl_mst_burst.sv"
`include "ahbl_mst_single_read32.sv"
`include "ahbl_mst_single_write32_apb_slv_nrdy.sv"
`include "ahbl_mst_tight_transfer.sv"
endpackage
to be honest, i know the bug now,but i dont know why . the class in the package can’t repeat?
I tried ti simulate with xcelium and Questa. Both showed the same error message.My guess is the factory gets confused.
To avoid such problems you should organize/package your data in a better way, seperating it with respect to the groups they are belonging to
ahbl_mst
apb_slv
ahb2apb
And you should have directories for the env, the test and the toplevel.
