I know this is an issue that was posted a lot on this forum but I somehow couldn’t find a solution in all the other posts I read about it. I somehow can’t get rid of this error, it seems like I’m giving the proper handle to the sequencer and everything but it still can’t be solved somehow. I hope someone here will understand what’s happening : here’s my code (the log is at the end).
class eth_tx_noc2fifo_env #(integer NOC2FIFO_ETH_MAC_ADDR_WIDTH,integer NOC2FIFO_ETH_ETYPE_WIDTH,integer NOC2FIFO_MPPA_ETHERNET_LANE_NB,integer NOC2FIFO_MPPA_ETHERNET_DATA_WIDTH) extends uvm_env;
typedef eth_tx_noc2fifo_env #(NOC2FIFO_ETH_MAC_ADDR_WIDTH,NOC2FIFO_ETH_ETYPE_WIDTH,NOC2FIFO_MPPA_ETHERNET_LANE_NB,NOC2FIFO_MPPA_ETHERNET_DATA_WIDTH) eth_tx_noc2fifo_env_t;
typedef eth_tx_noc2fifo_master_agent #(NOC2FIFO_ETH_MAC_ADDR_WIDTH,NOC2FIFO_ETH_ETYPE_WIDTH,NOC2FIFO_MPPA_ETHERNET_LANE_NB,NOC2FIFO_MPPA_ETHERNET_DATA_WIDTH) eth_tx_noc2fifo_master_agent_t;
typedef eth_tx_noc2fifo_slave_agent #(NOC2FIFO_ETH_MAC_ADDR_WIDTH,NOC2FIFO_ETH_ETYPE_WIDTH,NOC2FIFO_MPPA_ETHERNET_LANE_NB,NOC2FIFO_MPPA_ETHERNET_DATA_WIDTH) eth_tx_noc2fifo_slave_agent_t;
typedef eth_tx_noc2fifo_bus_monitor #(NOC2FIFO_ETH_MAC_ADDR_WIDTH,NOC2FIFO_ETH_ETYPE_WIDTH,NOC2FIFO_MPPA_ETHERNET_LANE_NB,NOC2FIFO_MPPA_ETHERNET_DATA_WIDTH) eth_tx_noc2fifo_bus_monitor_t;
// Control properties
protected bit has_bus_monitor = 1;
protected int unsigned vip_is_master = 1;
protected string v_name;
// The following two bits are used to control whether checks and coverage are
// done both in the bus monitor class and the interface.
bit intf_checks_enable = 1;
bit intf_coverage_enable = 1;
// Components of the environment
eth_tx_noc2fifo_bus_monitor_t monitor;
eth_tx_noc2fifo_master_agent_t master;
eth_tx_noc2fifo_slave_agent_t slave;
// Provide implementations of virtual methods such as get_type_name and create
`uvm_component_utils_begin(eth_tx_noc2fifo_env_t)
`uvm_field_int (has_bus_monitor, UVM_ALL_ON)
`uvm_field_int (vip_is_master, UVM_ALL_ON)
`uvm_field_int (intf_checks_enable, UVM_ALL_ON)
`uvm_field_int (intf_coverage_enable, UVM_ALL_ON)
`uvm_field_string(v_name, UVM_ALL_ON)
`uvm_component_utils_end
// new - constructor
super.new(name, parent);
endfunction : new
// build
string inst_name;
super.build_phase(phase);
if (vip_is_master == 1) begin
master = eth_tx_noc2fifo_master_agent_t::type_id::create("master", this);
uvm_config_db#(string)::set(this,"master", "v_name", v_name);
else begin
slave = eth_tx_noc2fifo_slave_agent_t::type_id::create("slave", this);
uvm_config_db#(string)::set(this,"slave", "v_name", v_name);
if (has_bus_monitor == 1) begin
monitor = eth_tx_noc2fifo_bus_monitor_t::type_id::create("monitor", this);
uvm_config_db#(string)::set(this,"monitor", "v_name", v_name);
endfunction : build_phase
function void assign_vi(virtual interface eth_tx_noc2fifo_if #(NOC2FIFO_ETH_MAC_ADDR_WIDTH,NOC2FIFO_ETH_ETYPE_WIDTH,NOC2FIFO_MPPA_ETHERNET_LANE_NB,NOC2FIFO_MPPA_ETHERNET_DATA_WIDTH) eth_tx_noc2fifo_i);
master.assign_vi(eth_tx_noc2fifo_i);
slave.assign_vi(eth_tx_noc2fifo_i);
monitor.assign_vi(eth_tx_noc2fifo_i);
endfunction : assign_vi
endclass : eth_tx_noc2fifo_env
`endif
class eth_tx_noc2fifo_master_agent #(integer NOC2FIFO_ETH_MAC_ADDR_WIDTH,integer NOC2FIFO_ETH_ETYPE_WIDTH,integer NOC2FIFO_MPPA_ETHERNET_LANE_NB,integer NOC2FIFO_MPPA_ETHERNET_DATA_WIDTH) extends uvm_agent;
typedef eth_tx_noc2fifo_master_driver #(NOC2FIFO_ETH_MAC_ADDR_WIDTH,NOC2FIFO_ETH_ETYPE_WIDTH,NOC2FIFO_MPPA_ETHERNET_LANE_NB,NOC2FIFO_MPPA_ETHERNET_DATA_WIDTH) eth_tx_noc2fifo_master_driver_t;
typedef eth_tx_noc2fifo_master_sequencer #(NOC2FIFO_ETH_MAC_ADDR_WIDTH,NOC2FIFO_ETH_ETYPE_WIDTH,NOC2FIFO_MPPA_ETHERNET_LANE_NB,NOC2FIFO_MPPA_ETHERNET_DATA_WIDTH) eth_tx_noc2fifo_master_sequencer_t;
protected uvm_active_passive_enum is_active = UVM_ACTIVE;
eth_tx_noc2fifo_master_driver_t driver;
eth_tx_noc2fifo_master_sequencer_t sequencer;
`uvm_component_utils_begin(eth_tx_noc2fifo_master_agent_t)
`uvm_field_enum(uvm_active_passive_enum, is_active, UVM_ALL_ON)
endfunction : new
// build
if(is_active == UVM_ACTIVE) begin
driver = eth_tx_noc2fifo_master_driver_t::type_id::create("driver", this);
sequencer = eth_tx_noc2fifo_master_sequencer_t::type_id::create("sequencer", this);
uvm_config_db#(string)::set(this,"driver", "v_name", v_name);
// connect
driver.seq_item_port.connect(sequencer.seq_item_export);
endfunction : connect_phase
// assign the virtual interface
function void assign_vi(virtual interface eth_tx_noc2fifo_if #(NOC2FIFO_ETH_MAC_ADDR_WIDTH,NOC2FIFO_ETH_ETYPE_WIDTH,NOC2FIFO_MPPA_ETHERNET_LANE_NB,NOC2FIFO_MPPA_ETHERNET_DATA_WIDTH) eth_tx_noc2fifo_mi);
if (is_active == UVM_ACTIVE) begin
sequencer.assign_vi(eth_tx_noc2fifo_mi);
driver.assign_vi(eth_tx_noc2fifo_mi);
endclass : eth_tx_noc2fifo_master_agent
`endif
class eth_tx_noc2fifo_master_driver #(integer NOC2FIFO_ETH_MAC_ADDR_WIDTH,integer NOC2FIFO_ETH_ETYPE_WIDTH,integer NOC2FIFO_MPPA_ETHERNET_LANE_NB,integer NOC2FIFO_MPPA_ETHERNET_DATA_WIDTH) extends uvm_driver #(eth_tx_noc2fifo_transfer #(NOC2FIFO_MPPA_ETHERNET_DATA_WIDTH));
typedef eth_tx_noc2fifo_transfer #(NOC2FIFO_MPPA_ETHERNET_DATA_WIDTH) eth_tx_noc2fifo_transfer_t;
// The virtual interface used to drive and view HDL signals.
protected virtual eth_tx_noc2fifo_if #(NOC2FIFO_ETH_MAC_ADDR_WIDTH,NOC2FIFO_ETH_ETYPE_WIDTH,NOC2FIFO_MPPA_ETHERNET_LANE_NB,NOC2FIFO_MPPA_ETHERNET_DATA_WIDTH) eth_tx_noc2fifo_mi;
logic [127:0] noc_header;
`uvm_component_utils_begin(eth_tx_noc2fifo_master_driver_t)
endfunction : new
this.eth_tx_noc2fifo_mi = eth_tx_noc2fifo_mi;
// run phase
`uvm_info(get_type_name(), $psprintf("Starting driver run"), UVM_LOW)
reset_signals();
get_and_drive();
join
endtask : run_phase
class eth_tx_noc2fifo_basic_seq #(int NOC2FIFO_MPPA_ETHERNET_DATA_WIDTH) extends eth_tx_noc2fifo_master_base_seq #(NOC2FIFO_MPPA_ETHERNET_DATA_WIDTH);
`uvm_object_param_utils(eth_tx_noc2fifo_basic_seq #(NOC2FIFO_MPPA_ETHERNET_DATA_WIDTH))
function new(string name="eth_tx_noc2fifo_basic_seq");
super.new(name);
endfunction : new
virtual task body();
$display("seq body");
$cast(trans, create_item(eth_tx_noc2fifo_transfer_t::type_id::get(), m_sequencer, "trans"));
start_item(trans);
finish_item(trans); // <-- THE PROBLEM IS HERE
endclass : eth_tx_noc2fifo_basic_seq
class eth_tx_noc2fifo_master_sequencer #(int NOC2FIFO_ETH_MAC_ADDR_WIDTH,int NOC2FIFO_ETH_ETYPE_WIDTH,int NOC2FIFO_MPPA_ETHERNET_LANE_NB,int NOC2FIFO_MPPA_ETHERNET_DATA_WIDTH) extends uvm_sequencer #(eth_tx_noc2fifo_transfer #(NOC2FIFO_MPPA_ETHERNET_DATA_WIDTH));
//`uvm_sequencer_utils(eth_tx_noc2fifo_master_sequencer_t)
`uvm_component_utils(eth_tx_noc2fifo_master_sequencer_t)
//`uvm_update_sequence_lib_and_item(eth_tx_noc2fifo_transfer_t)
endfunction : new
endclass : eth_tx_noc2fifo_master_sequencer
virtual class tb_mppa_ethernet_tx_fifo_tests extends uvm_test;
`uvm_component_utils(tb_mppa_ethernet_tx_fifo_tests)
typedef ethernet_tx_fifo_refmodel #(ETH_TX_FIFO_NB,ETH_TX_MAC_LANE_NB) ethernet_tx_fifo_refmodel_t;
typedef eth_tx_noc2fifo_env #(ETH_MAC_ADDR_WIDTH, ETH_ETYPE_WIDTH, MPPA_ETHERNET_LANE_NB, MPPA_ETHERNET_DATA_WIDTH) ethernet_tx_noc2fifo_env_t;
uvm_table_printer printer;
ethernet_tx_noc2fifo_env_t noc2fifo_vip_env;
// Instantiate virtual interfaces of VIPs
virtual interface eth_tx_noc2fifo_if #(ETH_MAC_ADDR_WIDTH,ETH_ETYPE_WIDTH,MPPA_ETHERNET_LANE_NB,MPPA_ETHERNET_DATA_WIDTH) vir_noc2fifo_intf[ETH_TX_FIFO_NB];
function new(string name = "tb_mppa_ethernet_tx_fifo_tests", uvm_component parent=null);
super.new(name,parent);
endfunction : new
// Create noc2fifo environnement
noc2fifo_vip_env = ethernet_tx_noc2fifo_env_t::type_id::create("noc2fifo_vip_env", this);
uvm_config_db#(string)::set(this,"noc2fifo_vip_env", "v_name", "NOC2FIFO");
uvm_config_db#(int)::set(this, "noc2fifo_vip_env", "vip_is_master", 1);
printer = new();
printer.knobs.depth = 3;
function void end_of_elaboration();
super.end_of_elaboration();
`uvm_info(get_type_name(), $psprintf("\nPrinting the test topology :\n%s", this.sprint(printer)), UVM_LOW)
endfunction : end_of_elaboration;
function void connect();
super.connect();
// Connect noc2fifo interface
if(uvm_config_db#(virtual eth_tx_noc2fifo_if #(ETH_MAC_ADDR_WIDTH,ETH_ETYPE_WIDTH,MPPA_ETHERNET_LANE_NB,MPPA_ETHERNET_DATA_WIDTH))::get(this, "", {"noc2fifo_vif", 0}, vir_noc2fifo_intf[0]))
`uvm_info(get_type_name(),$psprintf("noc2fifo virtual interface found"), UVM_HIGH);
`uvm_info(get_type_name(),$psprintf("connecting noc2fifo env and virt intf"), UVM_HIGH)
noc2fifo_vip_env.assign_vi(vir_noc2fifo_intf[0]);
super.run_phase(phase);
endtask : run_phase
endclass : tb_mppa_ethernet_tx_fifo_tests
class eth_tx_fifo_simple_test extends tb_mppa_ethernet_tx_fifo_tests;
`uvm_component_utils(eth_tx_fifo_simple_test)
typedef eth_tx_noc2fifo_valid_seq #(MPPA_ETHERNET_DATA_WIDTH) eth_tx_noc2fifo_valid_seq_t;
function new(string name = "eth_tx_fifo_simple_test", uvm_component parent=null);
endfunction : new
eth_tx_noc2fifo_basic_seq #(MPPA_ETHERNET_DATA_WIDTH) base_seq;
`uvm_info(get_type_name(), $psprintf("Starting test eth_tx_fifo_simple_test"), UVM_LOW)
uvm_test_done.raise_objection(this);
base_seq = eth_tx_noc2fifo_basic_seq #(MPPA_ETHERNET_DATA_WIDTH)::type_id::create("base_seq");
base_seq.start(noc2fifo_vip_env.master.sequencer);
uvm_test_done.drop_objection(this);
endtask : run_phase
endclass : eth_tx_fifo_simple_test
Here is my error :
UVM_FATAL @ 5000: uvm_test_top.noc2fifo_vip_env.master.sequencer [sequencer] send_request failed to cast sequence item
Here is the test topology :
