My question: is it possible to sample a clock signal of same frequency as sampling clock in assertions with $rose?
Well I tried but it’s not working, but instead of $rose we used:
property p1;
@(posedge clk1) (t1) ##0 (@(posedge clk2) 1) |-> t2 =$time;
end property
// clk1 = clk2
user49
January 18, 2019, 12:04am
2
In reply to ben@SystemVerilog.us :
but I just want to ask that is it so that $rose,$changed,$stable any of the system tasks doesnt work for same sampling and master clocks.i.e when clk1= clk2.
property test;
@(posedge clk1) $rose(clk2) |-> (t1 == $time) //wont work
$changed
$stable
user49
January 18, 2019, 5:51pm
4
In reply to ramandeepk :
$rose,$changed,$stable any of the system tasks doesn’t work for same sampling and master clocks.i.e when clk1= clk2.
With the property below, it is always vacuous when clk1= clk2 because @(posedge clk1)the sampling of clk2 is always ZERO, thus at every cycle there is no change.
property p_rose;
realtime t;
@ (posedge clk1) ($rose(clk2), t=$realtime) |-> ($realtime==t);
timeunit 1ns; timeprecision 100ps;
bit osc, clk1, clk2, a, c;
realtime period =10ns;
initial forever #(period/2) osc=!osc; // oscillator
property p_c;
realtime t;
@ (posedge clk1) (1, t=$realtime) |-> @ (posedge clk2) ($realtime==t);
ap_c: assert property(p_c) $display("time:%t assertion passed ", $time);
$display("time: %t assertion failed ", $time);
property p_rose;
realtime t;
ap_rose: assert property(p_rose) $display("time:%t ap_rose assertion passed ", $time);
$display("time: %t aproseassertion failed ", $time);
bit va;
#20;
$display("clk1 and clk2 INSYNC");
repeat(10) begin
va=1'b1;
@(osc);
clk1 <= osc;
if (va) clk2 <= osc;
else #1 clk2 <= osc;
$display("-----------------------");
$display("clk1 and clk2 OUT OF SYNC");
repeat(10) begin
va=1'b0;
@(osc);
clk1 <= osc;
$stop;
# time: 250 assertion passed
# time: 350 assertion passed
# time: 450 assertion passed
# time: 550 assertion passed
# clk1 and clk2 OUT OF SYNC
# time: 650 assertion passed
# time: 760 assertion failed
# time: 860 assertion failed
# time: 960 assertion failed
# time: 1060 assertion failed
SVA: Package for dynamic and range delays and repeats - SystemVerilog - Verification Academy
SVA in a UVM Class-based Environment
FREE BOOK: Component Design by Example
… A Step-by-Step Process Using VHDL with UART as Vehicle
http://systemverilog.us/cmpts_free.pdf
