Sampling 'clk' in concurrent SVA
One of the designer’s on our team wants to write an assertion to check that ‘clk’ on any edge of ‘clk’ has known value:
assert property( @(clk) disable iff (rst) (~$isunknown(clk)))
what are the implications of sampling ‘clk’ itself on any edge of ‘clk’ ?
In reply to Jartar:
If clk remains unknown, you will never get an assertion failure.
There might be performance overhead depending on the frequency of clk relative to other clocks.
A better approach might be to look at conditions that might cause clk to gho to X and perhaps use formal tools to check for that.
In reply to Jartar:
The sampled value of signal clk is its value at the Preponed region.
Thus, for clk going from X to 1, the sampled value of clk is X.
For clk going from 1 to X, the sampled value of clk is 1
See my paper: Understanding Assertion Processing Within a Time Step (Horizons Feb 27, 2023 issue)
This paper details how evaluation regions should be handled by a simulator as described in the SystemVerilog LRM; this should give you a better understanding of how assertions work.
EPWave Waveform Viewer waveform
module m;
  logic clk, rst=0;
  int pass, fail;
       pass=pass+1; else fail=fail+1;
    $dumpfile("dump.vcd"); $dumpvars;
    #2 clk=1; #2 clk=1'bX; #2 clk=0; #2 clk=1'bX;
    #2 $finish;
Ben@systemverilog.us
or Links_to_papers_books - Google Docs
