Running sequences parallelly on one sequencer
How two sequence can run on a sequencer parllelly? I mean, If I run two sequence in fork-join, then both sequences will start executing together or one by one?
phase.raise_objection(this);
    seq_A.start(my_env.my_agent.my_seqr);
    seq_B.start(my_env.my_agent.my_seqr);
   join
phase.drop_objection(this);
in above code, seq_A, seq_B will get the access to driver at the same time or one by one ?
In reply to vineet:
Only one at a time using the sequencer’s arbitration scheme determined by set_arbitration(). In this case, the order is not defined.
Hi!! I am facing the same issue… just after 7 years, do you still remember the solution?
