Running parellel sequences
how to start two sequences (read sequence and write sequence) in UVM testclass without any contradiction ?How many ways we can perform this task ?
In reply to vlsique:
You want to start these sequences in parallel? You can use fork/join, this is easiest way:
  read_seq.start(read_agent.read_sequencer);
  write_seq.start(write_agent.write_sequencer);
join
Fork/join will spawn 2 threads running parallel, each process will start a sequence with specific sequencer. It will wait for all threads finish before executing the next statement.
In reply to chris_le:
can we implemwnt semaphores method to avoid contradiction ??
What do you mean about “avoid contradiction”? Can you describe your problem?
Virtual sequence can help you to manage multiple sequences.
https://verificationacademy.com/cookbook/sequences/virtual
I mean two process one is write sequence and other is read sequence ,read sequence is waiting for write sequence to complete, or any events defined in write sequence , read sequence is waiting for any event to trigger defined in write sequence
How we will synchronize it ?
In general how to synchronize sequences in testcase ?
If you have to implement exclusive access you have to spend effort to guarantee this. One approach is to use semaphores.
