class ahb_env extends uvm_env;
ahb_agent agent1_h;
virtual task main_phase(uvm_phase phase);
for (int i=0; i < 5; i++) begin
uvm_config_db #(int)::set (this, "agent1_h", "loopCount", i);
class ahb_agent extends uvm_agent;
if (uvm_config_db#(int)::wait_modified(this, "", "loopcount")) // this is line 59
`uvm_info(get_type_name(), $psprintf("getting i value after waiting, loopcount = %0d", i), UVM_LOW);
I get the following error:
** Error: (vsim-8220) ahb_agent.sv(59): This or another usage of ‘<class-spec#743>::wait_modified’ inconsistent with ‘task’ object.
Region: /file_list_svh_unit
** Error: (vsim-8220) ahb_agent.sv(59): This or another usage of ‘<class-spec#743>::wait_modified.$$’ inconsistent with ‘(null)’ object.
Error loading design
How to resolve the errors? Thank you.
