run_test in top module is a function or a task. How run_test works after passing the test name through +UVM_TESTNAME switch? what happens after calling run_test?
In reply to agoel:
run_test is a virtual task defined in uvm_root, which is extended from uvm_component.
When testcase name is provided in run_test argument or passed through +UVM_TESTNAME, the uvm_root creates this testcase and starts executing all the phases one by one.
Ref:
