In a case we receive randomization errors in log, for example:
Solver failed when solving following set of constraints
Randomization failed in uvm_rand_send_with action
Error-[CNST-NPE] Constraint null pointer error
Is it possible to use the uvm_report_catcher and change these messages to be UVM_FATAL? I mean that the test will finish simulation on detection of these strings, since these errors are not of a UVM_INFO, UVM_WARNING or UVM_ERROR severity?
Is it a common practice? Or advised?
The best practice is to not use the `uvm_do_* macros.
Instead, you should create(), randomize() and send/start your sequence_items/sequences using the direct API calls. You can then catch any randomization failure with the appropriate action.
In reply to Michael54:
I was interested to hear if as general practice, is it a good idea to add few messages to the uvm_report_catcher which will assert the action of $finish simulation, instead of all the time checking if randomization worked?
My question is not only related to the uvm_do* macros, I know that is better to use the: create, randomize (query if randomize was successful) and send/start. I am working on IP/SoC and reusing sequences written by sub-IP block owners, all the sequences there are written using the sequence macros (uvm_do*), and not interested in re-writing their code… pretty much a headache to ask them do anything different…
Is it easy to achieve it using the uvm_report_catcher construct?
Is this approach correct from methodological point of view?
In reply to cgales:
@Michael54: You have 2 options to change the uvm verbosity:
(1) Override the default report_catcher, especially you have to implement
function action_e catch
(2) you can use
set_report_severity_id_action_hier
(what Srini is proposing)
Finally it is up to you to make your decision.
