Returning (early) from a task
Wanted to get some good programming advice on this…
I’ve got a handful of tasks that all call value_OK() at the beginning. The function returns a pass/fail, which I use to call reject_value, and then return. Could I roll reject_value() and return into the value_OK() function? Can a function cause the calling task to exit; perhaps it’s a bad idea!
task do_something1(uint32_t value);
  if (!value_OK(value)) begin
    reject_value();
    return;
task do_something2(uint32_t value);
    reject_value();
    return;
    reject_value();
    return;
In reply to bmorris:
Unfortunately
return
only goes back one level of the call stack. You might think about restructuring your code not to need a return.
if (value_OK(value)) begin
    reject_value();
If you change reject_value() into a function that always returns 0, you can use short-circuiting
if (value_OK(value) || reject_value()) begin
