Reset code in uvm
HI All,
What could be the best approach to have reset code in uvm_driver
//APPROACH_1 : Having separate task for reset inside driver
drive_reset();
forever begin
drive_to_dut();
seq_item_port.item_done();
task drive_reset;
vif.reset=1;
repeat (2) @(posedge vif.clock);
vif.reset=0;
//APPROACH_2 : Using built_in phase (reset_phase) in driver
virtual task reset_phase(uvm_phase phase);
phase.raise_objection(this);
vif.reset=1;
vif.reset=0;
phase.drop_objection(this);
//APPROACH_3 : writing reset code in tb_top (testbench top) file
module tb_top;
reset=1;
#5 reset=0;
//APPROACH_4 : Having separate reset sequence
class my_seq_item extends uvm_sequence_item;
`uvm_object.....
rand logic reset;
class my_base_seqeunce extends uvm_sequence;
task body;
reset_pkt = my_seq_item::type_id::create("reset_pkt");
start_item(reset_pkt);
reset_pkt.randomize() with {reset==1};
finish_item(reset_pkt);
//now, we can use this my_base_sequence before we start the actual test_sequence inside uvm_test
//Actual Question : Which is the best or recommended approach to have reset code while verifying a design.
Any limitations with these, please suggest
Are you asking how to drive reset stimulus, or how to handle observed reset conditions?
If it’s about stimulus, I think the UVM way would be to have some sequence item(s) cause your driver(s) to drive the reset.
If it’s about reacting to a reset, I don’t think there is broad concensus. Here someone has compiled some approaches: UVM kit: Reset Handling
My opinion would be to avoid relying on reset_phase for this, since the phases are global AFAIK. I would instead either include a reset signal in the driver’s interface, or give the driver a reset function/port.
@thomas.watson
Yes, the phases should be global, unless you will start define different UVM domains…
So what would you recommend when your TB (e.g. complex SoC) has hundreds of 3rd party VIPs based on SV/UVM?
Asking from curiosity and open discussion…
@MichaelP I definitely don’t have the experience to say. Anyone else?
