In reply to naaj_ila:
I wanted to write an assertion in which
- When Reset goes from 1 to 0, ElecIDle=1
2.From there EleIdle should be 1 till Reset=0,It should not change in between
On your 2nd requirement, you most likely mean
"2.From there EleIdle should be 1 till another fall(Reset),It should not change in between
initial begin // Needed to create only ONE assertion
wait($fell(Reset));
ap_reset2idle: assert property(@(posedge clk)
$fell(Reset) |-> ElecIDle[*1:$] ##1 $fell(Reset));
// Typical application of reset, from my 4th Edition SVA book
module m10_19; // /ch10/10.19/m10_19.sv m10_19.png
bit clk, reset_n, system_ready;
default clocking cb_clk @ (posedge clk); endclocking
wait(system_ready); // You need to assess the need for this.
a1: assume property( // you can also use assert property
##1 $rose(reset_n) |-> always reset_n);
// The ##1 is needed to detect the $rose
- SystemVerilog Assertions Handbook 4th Edition, 2016 ISBN 978-1518681448
