Hello I am running test and my question is end_of_elaboration phase prints the topology informaion but report phase is not working, below
is my program…
virtual function void end_of_elaboration();
print();
`uvm_info(get_type_name(), "----------TEST PASS------------------", UVM_NONE)
function void report_phase(uvm_phase phase);
uvm_report_server svr;
super.report_phase(phase);
svr = uvm_report_server::get_server();
//`uvm_info(get_type_name(), "----------TEST PASS------------------", UVM_NONE)
if(svr.get_severity_count(UVM_FATAL)+svr.get_severity_count(UVM_ERROR)>0)
`uvm_info(get_type_name(), "---------------------------------------", UVM_NONE)
`uvm_info(get_type_name(), "---- TEST FAIL ----", UVM_NONE)
`uvm_info(get_type_name(), "---- TEST PASS ----", UVM_NONE)
It is useless to print simulation results in the end_of_elaboration_phase, because the simulation hasn’t startexd yet.
Did your simulation reach the report_phase? This will be indicated automatically in your simulation log-file.
In reply to keshav_chokshi:
I am new user can you tell me whare can i see simulation log file ?
please check if you have UVM_MAX_QUIT_COUNT set, does your test have any UVM_ERROR/FATAL ?
if the test exits with UVM_EXIT ( on FATAL or if quit count is reached ) , the report_phase is not executed, so what you are trying to do here wont work if your test exits with UVM_EXIT.
if you want to print any information, when tests encounters UVM_EXIT, only function to use is pre_abort ( in uvm_component )
// Function: pre_abort
// This callback is executed when the message system is executing a
// <UVM_EXIT> action. The exit action causes an immediate termination of
// the simulation, but the pre_abort callback hook gives components an
// opportunity to provide additional information to the user before
// the termination happens. For example, a test may want to executed
// the report function of a particular component even when an error
// condition has happened to force a premature termination you would
// write a function like:
//| function void mycomponent::pre_abort();
//| report();
//| endfunction
// The pre_abort() callback hooks are called in a bottom-up fashion.
When timeout expeires you might not have any UVM_ERROR. In this case you have a tsructural problem. Your simulation might hang or it runs in an infinite loop. The question for UVM_ERROR is not relevant in this case.
Per definition pre_abort is only execuetd on UVM_EXIT and this depends on your parameter UVM_MAX_QUIT_COUNT.
The main reason to implement pre_abort was if the test is being killed by UVM_TIMEOUT, it never calls post-run phases.
So thats why I put check_phase inside pre_abort.
What I think is happening is. check_phase generates an UVM_ERROR. Because of max_error_count being 1, it exits and calls pre_abort, which again calls check and that calls pre_abort.
If this is true , then I think its a UVM bug.
OK, I bekieve you are hunting for something you could see implementing appropriate uvm_info and uvm_error in your testbench code.
Investigate this line of code.
668195000: ![31mUVM_ERROR[0m! [[36muvm_test_top.env.LLC_SCB[0m] [31mrdAddrQ is not empty[0m (/project/freya/fba/design/sharatk/dv_0/fbsource/fbcode/infra_asic_fpga/ip/fb_inference/dv/fb_inf_llc/gen/…/env/fb_inf_llc_sb_ext.sv:1421)
What are you doing here?
