my queue has 12 entries… every entry contains {id.address}. i want to pop back and want to read address only (means first index only) everytime.
i am saving like:
RADDR_Q.push_front({axi_vif.id,axi_vif.address});
i am trying to fetch index-1 value like:
RADDR_Q.pop_back[1];
is it right?
as it’s not showing error but data is also not coming
In reply to Er. Shipra:
what do you mean “pop back and want to read address only (means first index only)”?
“pop back” → remove from tail
“read address (first index only)” → read head item
module automatic test;
function void run;
typedef struct {int addr; int data;} item;
item q[$];
item tmp, tmp1;
// init q has 12 entries
repeat(12) begin
tmp.addr = $urandom_range(10, 0);
tmp.data = $urandom_range(200, 100);
q.push_back(tmp);
// read the first item's addr from head and won't change q structure
$display("ans:%0d", q[0].addr);
// remove an item from tail
tmp1 = q.pop_back();
$display("tmp1:%p", tmp1);
initial run();
