Register_seq
Hello guys ,
from register sequence I wpuld like to write the value in register fields in bellow code only 0th location will update what about else location is there any other way of writing (sysntax) ,
regmodel.DLALR0.LA_31_LSB.write(.status(status) , .value (cfg.local_min_addr[0]));
In reply to raj@123:
We cannot see how the configuration object is defined and how the register model looks like wrt the register fields.
Please show some more code.
wchich class you would like to see
Firstly, I do not understand what you want to do. Do you have a serious of register fields you want to write or what is your intention.
I guess the field local_min_addr is a dynamic array.
You shoud say which fields of this dynamic array you want to write to which register fields.
