Register Assistant - Failed to load the JNI shared library
When I try to invoke vreguvm from the command line or with the -gui option, I get the message:
Failed to load the JNI shared library “/home/packages/questasim_10.2c/questa_sim/RUVM_4.3/jre/bin/…/lib/i386/client/libjvm.so”.
the path and file both exist. I can’t find any Reg Assistant installation notes that might help explain any path or variable that I am missing.
Anyone have any good hints?
Regards - Cliff Cummings
In reply to cliffc:
Cliff, that appears to be a java virtual machine call. This will be the java machine that the eclipse based RUVM application runs under.
I had issues with GTK2 libraries not installed correctly in the same context so i would read the documentation and confirm you have the correct packages installed.
In reply to Phill_Ferg:
Hi, Phil -
Thanks for the response and you may be correct. I have installation documentation for Questasim, but I can’t find installation documentation for RUVM. I did the RUVM-install from the install-script and that seemed to go okay, but I don’t know anything about GTK2 libraries. Any pointers to related documentation would be appreciated.
Regards - Cliff
