Register Adapter With Strobe Based Register Access ? Had anyone came across such situation?
Hello !!
a. I have a scenario where in the Block “x” registers are configured through APB bus !
b. But the tricky part is that the APB bus is strobe based access !!!
c. If I do a register write, then the adapter basically have to convert the register based TX to the Bus based TX. But here the proper register offset address and the strobe value needs to be set instead of default register address !
Had anyone came across such situation i.e. block register access using APB with Strobe based access ? If so share in your thought process !!
Appreciate Your Help !!
Regards,
Desperado
