I probably see what is wrong. But considering that only a child_handle calls a new() and memory is created only for the child_handle which is then passed onto parent_handle, how is it that there are different parent_handle.a and child_handle.a variables even though I didnt create a parent_handle object?
Your use of the term “parent” and “child” for classes with inheritance is misleading. When you extend a class , then construct it, the two classes become one. Better terms are “base” and derived" classes. When you construct a “derived” class, you are constructing everything in the base as well.
Yes but isn’t the value of ‘a’ mutually exclusive ? I don’t understand why 2 a’s are created when I have constructed only one object which happens to be the derived class. And that value in the derived class overrides inherited value as per the LRM.
When you say “2 classes become one” shouldn’t the value in the derived class override the value inherited from base class ?
Constraint blocks are virtual, meaning when the constraint block in derived class has the same name as parent class, it would get override. I have modified the code, which works for your requirement !!
module polym_cons();
class parent;
rand int unsigned a;
constraint c1{
(a < 10);
class child extends parent;
constraint c1{
(a > 10);
parent parent_handle;
child child_handle = new();
initial
parent_handle = child_handle;
parent_handle.randomize();
$display("a = %d",parent_handle.a);
class A;
int a=10;
function void disp();
$display("a=%d",a);
class B extends class A;
int a=20;
program main();
A a;
B b;
b =new();
b.disp(); //diplays a=10
$display("b.a=%d",b.a); // displays a=20
endprogram
My questions is, now b has two a’s and a disp() function. How does simulator know which value of a to display when I call b.disp() ?? what is the OOP concept governing this situation?
2nd question: How can I access a of base class with derived class handle in program block?
Hi,
When your creating an object of the derived class the simulator adds super.new() constructor and allocates memory for the base class as the derived class is inherited.Hence there will be base class ‘a’ and derived class ‘a’ being created(name hiding).
As per the LRM only virtual methods can be overriden.
class A;
int member1;
class A1 extends A;
int member2;
class A2 extends A;
int member3;
A1 a1_h = new();
A2 a2_h;
// this is not legal
a2_h = a1_h;
There no cast that would make it legal. a2_h.member3 does not exit in the constructed object.
class A;
int a=10;
virtual function void disp();
$display("Base a=%d",a);
class B extends A;
int a=20;
$display("Derived a=%d",a);
module tb();
A a=new;
B b;
$cast(b,a);
b.disp(); //
a.disp(); //
$display("a.a=%d",a.a); //
I have a compilation error when I do a $cast(b,a) without doing “a=b”. Why is that? Then what is the point having $cast?
Error-[DCF] Dynamic cast failed
testbench.sv, 25
Casting of source class type ‘A’ to destination class type ‘B’ failed due to
type mismatch.
Please ensure matching types for dynamic cast
You code comment say you have a run-time error, but your text says you have a compilation error. Also, you seem to be missing an
initial begin/end block. Please correct your post because it really matters to the question you are trying to ask.
$cast does not create or copy objects; it tries to copy a handle from one class variable to another. Please see my course on SystemVerilog OOP, especially the second session.
So in the above code I have posted, Class A’s handle ‘a’ is created by ‘new’. Then I do a $cast(b,a). Why is there an error ‘type mismatch’?
But the following code works and why is that?
class A;
int a=10;
class B extends A;
int a=20;
module tb();
A a;
B b=new;
b=a;
$cast(b,a);
b.disp(); //
a.disp(); //
Hi Dave,
Your sv-class-OOP courses are excellent !! Heavily loaded with important information. The way you described all of them seamlessly is awesome!
