Regarding const'() cast
Hi ,
I was trying to understand working of const’() cast.
LRM 6.24.1 mentions
An expression may be changed to a constant with a const cast.
const'(x)
Consider the following code :
class C;
  rand bit[2:0] a ;
  function void pre_randomize();
   // 'a' could be assigned here
  constraint CONST { a == const'(a) + 1 ; }
C c1;
module test;
  c1 = new();
  repeat(5) begin
    if( c1.randomize() )
      $display("Success with %p",c1);
    else  $display("Fails");
      // c1.a could also be assigned here prior to call randomize() again
Consider following 3 cases where variable ‘a’ is assigned.
  1. Via pre_randomize()
  2. Via post_randomize()
  3. Via assignment to variable ‘a’ after randomize() call i.e assignment is done after post_randomize()
When we mention const’(a) which value of a should it pick ? Is it just before the constraints are solved i,e value assigned in pre_randomize() ?
There could be any possible combination of 1,2,3 i.e all 3 exist or only 1 and 2 exist or 1 and 3 exist , etc
In reply to hisingh:
As with any other non-random variable or expression, the constraint solver uses that values after pre_randomize completes to solve the constraints.
Thanks Dave.
So in absence of assignment within pre_randomize() , the value assigned procedurally would be used. In absence of both assignment within pre_randomize() and procedural assignment after randomize() is successful , the value assigned within post_randomize() would be used.
When casting an expression as a constant, the type of the expression to be cast shall pass through unchanged. The only effect is to treat the value as though it had been used to define a const variable of the type of the expression.
I see some simulators failed the compilation, based on the statements above it seems to be illegal to do constant cast to rand variable in constraint.
Pass through unchanged means it keeps the value it has as if defined as a const. So randomization can’t change the value.
If randomization can’t change the value of a, how could this constraint be satisfied in this case?
Isn’t it a conflict?
Hi Dave
I am having hard time understanding how this constraint works. If a rand variable is termed const, then how will it randomize based on this constraint. Couldn’t find answer in the LRM
The const'(epxression) cast gets applied to an expression, which might contain a random variable. The constraint solver compues the value of the expression as if it were evaluated at the end of pre_randomize(). It’s then free to change any random variables the expression uses during randomize(). The const'(expression) value does not change during randomization–it remains constant.
