In the RAL model reg_field.configure method, when the argument {.volatile(0)} has to be setted to zero and when it has to be setted {.volatile(1)} to one , on what register specification this has to be decided?
function void configure( uvm_reg parent,
int unsigned size,
int unsigned lsb_pos,
string access,
bit volatile,
uvm_reg_data_t reset,
bit has_reset,
bit is_rand,
bit individually_accessible );
In reply to vijay kumar gannoju:
The UVM Reg model considers a RW register “volatile” if it can change its value through some other mechanism not observable through a monitored interface. This means if you write to it, you cannot predict its value from a subsequent read.
could you pease elaborate it…
Hi Dave ,
Lets say we have a register with SW access as “RO” and HW access as “RW/WO” .
So if we were to write into it ( obviously it wouldn’t be reflected in register ) , so when we read it back ,
[A] Should it ( mirrored value ) would expect the default value to be read back ?
[B] But since HW is free to write into it , would we get a mirrored value mismatch ?
Even using volatile bit for the fields doesn’t resolve the issue
So how should we solve this issue ?
In reply to TC_2017:
There is no such thing as SW versus HW access—it’s all hardware.
This might answer your question.
Hi Dave ,
Is the volatile bit set , sufficient for no mismatch error ( between mirrored value and value read from register ) ?
Although I have set volatile argument for all uvm_reg_fields within a register ( with access as “RW” ) , I still see a mismatch error on doing a random write and read . The value read is different than the random value written , hence the mismatch .
Can you please elaborate the above explanation. Unable to understand clearly
