I’m writing small code to check an address belongs to a memory region (including cross region). I came up with idea using recursion function. Here is my code:
virtual class bit_utils#(WIDTH = 32);
static function bit in_range(bit[WIDTH-1:0] val_a, bit[WIDTH-1:0] min_a, bit[WIDTH-1:0] max_a);
if(min_a <= max_a) begin
in_range = (val_a inside {[min_a:max_a]});
else begin
in_range = in_range(val_a, min_a, {WIDTH{1'b1}}) || in_range(val_a, {WIDTH{1'b0}}, max_a);
module top;
// Check 8'FE belongs to [8'hFC : 8'h01]
$display("in_range = %0d", bit_utils#(8)::in_range(8'hFE, 8'hFC, 8'h01));
It works. But I’m not sure it’s safety or not. Please help me clarify!
By the way, do you have any better to idea for this problem?
Thanks.
