I would like to know whether it is possible or not read just the first word from line with $fscanf() as placed below
$fscanf(fd, "%s%*[^\n]", str);
In C++, that statement (%s%*[^\n]) reads just the first word from line, store the word to str and throw away rest up to a new line. Is that kind of syntax supported in SystemVerilog, I think no after a couple of check in simulation? Any alternative SystemVerilog dedicated syntax to do that?
I have text file including a random amount of columns up to ten pieces. Those columns are separated with white space characters (blanks or tabs). Inside my scoreboard, I am only interested about the first column (i.e. first word) of the line. Text file is for example as follows:
sss sss sss sss ssss
That’s why I wanna just use syntax I typed in my first post to this thread. I want also sideline $sscanf() function as it adds redundancy since $fgets() need to called before $sscanf() to get line as string input for the scan function. So, please give info if you know how “%s%*[^\n]” syntax should be interpreted in SV. I think $fscanf() is imported mostly from C language’s fscanf, so why that syntax is tackled?
string line;
string first_word_column [];
fd = $fopen ("myfile.txt", "r");
while (!$feof(fd)) begin
code = $fgets (line, fd); //Get entire line
code = $sscanf (line, "%s", first_word_column[i]); //Get first word of that line
i++;
$fclose (fd);
No, that is not what I want to see. As I stated already a couple of times, I would like to execute read operation with C-style onliner using $fscanf() as
Not with loop construct you proposed.
SystemVerilog agrees * assignment character
$fscanf(fd, "%s%*s", str); // == read two consecutive words but don't assign the second one just the first one (please refer to LRM to see more info on that)
So, I am repeating myself again to ask how this C-style “%s%*[^\n]” syntax should typed in SystemVerilog style if possible? I am not finding any loop construct to overcome this, those constructs are obvious already.
The specification for the formatting string in SystemVerilog is very basic, but there are backward compatibility issues that prevent extending it to match the C++ formatting capabilities directly. The only way to access the exact formatting capabilities of C++ is to import the routines through the DPI.
That’s was very much the answer I was looking for, thanks. As you stated backward compatibility issues, is the SystemVerilog LRM committee working with those for the future generation of SystemVerilog? BTW, if trying to import C++ fscanf through DPI, how that should be typed practically, probably something starting with
import "DPI-C" function int fscanf(int fd, string format, ...); // ???
In reply to Vaino:
The IEEE SystemVerilog committee has been inactive for the last 3 years, but is now just starting up. It would be very difficult to get the same behavior as C++ since Verilog, and now SystemVerilog have different meanings for things like %h.
The DPI has limitations that makes importing fscanf() directly a problem. You cannot import a routine having variable numbers of arguments with arbitrary types. So you will need to write a C wrapper around fscanf() for each use case.
