How can I effectively disitribute ones in a n bit vector so that its cross sum matches a given value by using Systemverilog randomization constraints?
My current solution is:
int temp_value,
temp_array[$];
bit [n-1:0] vector;
int cross_sum;
vector = {{n}{1'b0}};
for(int i = 0; i < cross_sum; i++)
void'(randomize(temp_value) with {temp_value inside {[0:n-1]} && !(temp_value inside {temp_array});});
temp_array.push_back(temp_value);
vector[temp_value] = 'b1;
This solution is too slow in simulation for n=2^14.
Is cross_sum is also random type or fixed. ??
till now i understand that you want to put ones in random position in vector. That number of number of ones should not be greater than cross sum . please correct me if I am wrong .
Hi
May be this code help you .
int unsigned cross_sum ;
rand int [n-1:0] vector ;
rand int unsigned enble_1[$] ;
constraint enble_size_sum { enble_1.size == n ; enble_1.sum == cross_sum ;}
constraint enble_values { foreach(enble_1[i]) enble_1[i] inside[0:1] ; }
constraint vector_1 {foreach(vector[i]) { vector[i] == enble_1[i] ; } }
You can use either
void'( randomize(vector) with { $countones(vector) == cross_sum } );
or
bit temp_array[n];
bit [n-1:0] vector;
int cross_sum;
void'(randomize(temp_array) with { (temp_array.sum(b) with (int'(b)) == cross_sum); } );
vector = type(vector)'(temp_array);
Unfortunately this solution seems not to work on the Cadence Incisive Simulator (tried on version 12.20.009 and 13.10.003). It seems that the simulator get stuck in an infinite loop.
In reply to Chandra Bhushan Singh:
Cross_sum is a fixed value. I need the number of ones in vector to be equal to cross_sum.
How about this code? It seems not slow even when n is a big value.
parameter n = 16384;
int temp_value;
int temp_array[$];
bit [n-1:0] vector;
int cross_sum;
cross_sum = $urandom_range(1,n);
$display(" cross_sum: %0d",cross_sum);
for(int i = 0; i < n; i++)
temp_array.push_back(i);
temp_array.shuffle;
for(int i =0;i<cross_sum;i++)begin
vector[temp_array[i]] = 1'b1;
$display("vector: %b",vector);
I think Dave’s code works well for constraints. If you want to do it procedurally:
Compare the following code:
bit [n-1:0] pattern;
for(int i =0; i<N ; i++) // N= number of ones in array
patern[i] =1’b1;
pattern.shuffle();
In reply to sebastian.schmutz:
Here my two cents.
I find the solution provided in other thread important to be mentioned. That solution is in my opinion longer but quite more efficient than leaving the count function in the constraint solver.
That solution is about creating a vector of indices that you can shuffle, and then randomize the number of index you want to take from that vector to insert the ones. Take in mind that this doesn´t require any constraint and it doesn´t force the solver with try and error but just plain loops.
Here i present an example function where you can configure the max number of ones inside 3 vectors of 32,32 and 128bits respectively and that will be concatenated in one single vector.
function logic[BLK_AIRQC_NUM_IRQS-1:0] randomize_irq(int max_int_ones=15,int max_ext_ones=15,int max_sgi_ones=20);
automatic logic [BLK_AIRQC_NUM_IRQS-1:0] all_irqs_after_randomization=0;
automatic int irqs_128index_arr[BLK_AIRQC_NUM_IRQ_INT_G];
automatic int irqs_32index_arr[BLK_AIRQC_NUM_IRQ_EXT_G];
automatic logic [BLK_AIRQC_NUM_IRQ_INT_G-1:0] int_irqs=0;
automatic logic [BLK_AIRQC_NUM_IRQ_EXT_G-1:0] ext_irqs=0;
automatic logic [BLK_AIRQC_NUM_IRQ_SGI_G-1:0] sgi_irqs=0;
automatic int random_number_of_ones;
//allirqs= (MSB) sgi , ext , int (LSB)
//Initialization of indices
foreach(irqs_32index_arr[i]) begin
irqs_32index_arr[i]=i;//put indices on each element value
foreach(irqs_128index_arr[i]) begin
irqs_128index_arr[i]=i;//put indices on each element value
//end of initialization
irqs_32index_arr.shuffle;//randomize the order of the array or indices
assert(std::randomize() with {random_number_of_ones dist {['h1:max_ext_ones]:=100, 0:=0,['h0:32]:=50};});
for (int unsigned i=0; i<random_number_of_ones; i++) begin//now use the n first indices to put ones
ext_irqs[irqs_32index_arr[i]]=1;//put ones for IRQs using the index from the shuffled vector
assert(std::randomize(random_number_of_ones) with {random_number_of_ones dist {['h1:max_sgi_ones]:=100, 0:=0,['h0:32]:=50};});
sgi_irqs[irqs_32index_arr[i]]=1;//put ones for IRQs using the index from the shuffled vector
irqs_128index_arr.shuffle;//randomize the order of the array or indices
assert(std::randomize(random_number_of_ones) with {random_number_of_ones dist {['h1:max_int_ones]:=100, 0:=0,['h0:128]:=30};});
int_irqs[irqs_128index_arr[i]]=1;//put ones for IRQs using the index from the shuffled vector
all_irqs_after_randomization = {sgi_irqs, ext_irqs, int_irqs};
return all_irqs_after_randomization;
I hope it helps
Jonathan
