Randomize dynamic array with unique values
I have been asked to randomize a dynamic array with unique values with following conditions
  1. Unique key word can’t be used
  2. Use pre and post randomize functions
  3. Can not use foreach or any other loops in constraint
In reply to bachan21:
class A;
  typedef bit [2:0] number_t;
  rand number_t number;
  number_t recent_numbers[$];
  bit add;
    add = 1;
    foreach (recent_numbers[i]) begin
      if (recent_numbers[i] == number) begin
        add = 0;
        break;
      end else begin
        add = 1;
    if (add == 1) begin
      recent_numbers.push_front(number);
    if (recent_numbers.size() > 5)
       void'(recent_numbers.pop_back());
endclass : A
module top();
  A a = new();
    repeat(10) begin
    if(!a.randomize()) $display("Please look into randomization issue");
    if (a.recent_numbers.size() == 5) begin
      $display("recent_numbers = %p",a.recent_numbers);
endmodule : top
In reply to megamind:
Can you explain your code, because I cant find the declaration of any dynamic array
I have used queue , instead of dynamic array , if you use dynamic array then syntax will change for adding elements , nothing much in the logic should change. Does it make sense ?
Actually it is better to use queue, to handle element addition.
Yeah I got your logic.
You are randomizing the value and adding to the queue by randomizing for 10 times.
But can we modify the logic such that a dynamic array can be used instead of queue?
class A;
  number_t recent_numbers[];
    recent_numbers = new[5];
      recent_numbers[i] = i;
  endfunction : post_randomize
endclass : A
module top();
  A a = new();
    repeat(1) begin
      $display("----->> recent_numbers = %p \n",a.recent_numbers);
endmodule : top
class A;
  typedef bit [31:0] number_t;
  bit [16:0] random_num;
    recent_numbers.shuffle();
    random_num = $urandom();
    $display("random_num = %0d ",random_num);
      recent_numbers[i] = recent_numbers[i] + random_num;
endclass : A
module top();
  A a = new();
    repeat(10) begin
      $display(" >>> Recent_numbers = %p \n\n",a.recent_numbers);
endmodule : top
class packet;
  rand bit [4:0] valid[];
   constraint valid_c {
     valid.size() == 15;
     bit [4:0] tmp;
     valid[0] = $random;
     for(int i=1; i<valid.size(); i=i+1) begin//{
       bit flag=0;
       while(flag==0) begin//{
         tmp = $random;
         for(int j=0; j<i; j++) begin//{
           if(tmp == valid[j] ) begin//{
              flag=0; break;
           end//}
            flag=1;
         end//}
       end//}
       valid[i] = tmp;
     end//}
module tb;
packet pkt;
pkt = new();
$display("------------------------------------");
  if(!pkt.randomize()) $fatal(1, "Randomize Failed");
  foreach(pkt.valid[i]) $display("valid[%0d] = %d ", i, pkt.valid[i]);
