How to randomize a variable it is not declared as rand/randc?
In reply to anvesh dangeti:
bit Avariable;
initial Avariable = $urandom;
Pass the variable as argument to the randomize() call .
Eg :- obj.randomize(variable)
In reply to bl4ckp3rl :
Be careful with that advice. All constraints on obj still need to be honored.
It would help if the original question had more detail in what the motivation behind the question was.
I would suggest std::randomize([variable_list]) [with constraint_block]
Please refer to Section 18.12 of the IEEE standard.
Agree with Dave , i was thinking of following code
class base;
bit[2:0] addr;
constraint c{addr ==4;}
endclass:base
module tb();
base base_h;
initial
base_h =new();
base_h.randomize(addr);
$display("contents %0d ",base_h.addr);
