I have a few doubts related to randomization
(1) rand to randc Conversion using unique
class rand_2_randc ;
rand bit [2:0] b ;
bit [2:0] b_q[$] ;
constraint UNIQUE { ! ( b inside { b_q } ) ; }
function void post_randomize() ;
b_q.push_back(b);
if ( b_q.size() == 8 )
b_q.delete();
LRM says ::
“To reduce memory requirements, implementations may impose a limit on the maximum size of a randc
variable, but it shall be no less than 8 bits”
So a simulator may not support 32-bit randc variable
If I were to declare the packed dimensions of both ‘b’ and ‘b_q’ as 32-bit I would see performance issues
So I decide to split the 32-bit variable into two 16-bit variables
class rand_2_randc_Part2 ;
rand bit [15:0] b1 , b2;
bit [15:0] b1_q[$] , b2_q[$] ;
constraint UNIQUE { ! ( b1 inside { b1_q } ) ;
! ( b2 inside { b2_q } ) ;
b1_q.push_back(b1);
b2_q.push_back(b2);
if ( b1_q.size() == 2**16 )
b1_q.delete();
if ( b2_q.size() == 2**16 )
b2_q.delete();
[QA] My confusion is how do I achieve all 232 unique values ?
The above class won’t necessarily give me all 232 unique combinations if I call randomize() , 232 times on object of class rand_2_randc_Part2**
My next 2 questions are related to LRM .
(2)
LRM says ::
"Randomization shall not modify the actual object handle. "
[Q]**I understand that via constraints I can’t create objects , is the above line trying to say the same .
Or are there additional things too ?
LRM says ::
[b]" Object handles shall not be declared randc. "**
[Q][C] Why the above limitation ?
The properties within a object would be randomized only if the properties are rand/randc and the class handle is declared random too
( in another class as its property )
**Why does it make any difference if the class handle is declared rand OR randc .
Its how the properties are defined within the class that should decide the values**
