Randomization problem of enum in derived sequence item
hi
I made a base seq item like this and defined some enums and data items inside it. all data item are registered in factory with `uvm_field
class eth_rw extends uvm_sequence_item;
and i made another seq item derived from it and registered them
class ipv4_rw extends eth_rw;
typedef enum bit [3:0] {
 INVALID_IPV4                            =4'h0, //length is used instead
 IPV4_TYPE          =4'h4
} ip_version_e; // user typedef
  ip_version_e     ip_version;
  rand bit [3:0]     ihl;
  rand bit [7:0]     tos;
in the test i use this to start the generation of ipv4_rw
  set_type_override_by_type(eth_rw::get_type(), ipv4_rw::get_type());
the problem is the generated ipv4_rw has all ip_version=0 . but the ihl and tos is real random value.
when I add the constraint
    constraint version_c {
      ip_version == 4'h4;
the questasim report error in simulation . i have no other constraint for this value.
i used questa 10.1d, is there anything wrong with my code or it’s a bug of the tool?
[RNDFLD] Randomization failed in uvm_do_with action
thanks
It appears that you are missing a “rand” in front of the ip_Version declaration.
thank you, i can’t believe how foolish i am.
