hi ,
i am new to system verilog randomization , can i know how to randomize the part of the data only , for example i have 8 bit data , in that 3bit is crc , which i do not want to randomize, like to calculate and replace that bit with it return value .
In reply to sekharece413:
There are a few different things you can do:
- You can constrain the crc bit with the function
constraint c_crc {data[7:5] == crc_func(data[4:0]); }
- After randomization, you can just replace the crc bits with the return value of the function. It will not matter if they were random before.
- You can add a constraint that leaves the 3 bits in their current state.
constraint c_crc {data[7:5] == const'(data[7:5]); }
I think 1) is your best option.
