Hi ,
i am trying to randomize an array in my seq but i see array value being 0 all the time.
what i am trying to do is randomizing the array in the sequence itself and write the random values to some registers as per their value restrictions.
because of restrictions i need to add constraints on which bits has to be zero all the time.
class seq1 extends uvm_sequence;
`uvm_object_param_utils( seq1 )
bit[23:0] wr_addr ;
int random_wr_data[];
int rd_data[];
constraint C1{ random_wr_data.size() == 'd17;
foreach(random_wr_data[i]){
if(i==0) { random_wr_data[i][31:12] =='0 ; random_wr_data[i][0]=='b0; }
else if(i==1) { random_wr_data[i][31:13] =='0 ;}
else if(i==2) { random_wr_data[i][31:13] =='0 ; random_wr_data[i][11]=='b0; random_wr_data[i][0]=='b0; }
else if(i==3) { random_wr_data[i][31:16] =='0 ; }
else if(i==4) { random_wr_data[i][31:16] =='0 ; }
else if(i==5) { random_wr_data[i][31:15] =='0 ;}
else if(i==6) { random_wr_data[i][31:16] =='0 ; }
else if(i==7) { random_wr_data[i][31:9] =='0 ; }
else if(i==8) { random_wr_data[i][31:16] =='0 ; }
else if(i==9) { random_wr_data[i][31:14] =='0 ; }
else if(i==10) { random_wr_data[i][31:1] =='0 ; }
else if(i==11) { random_wr_data[i][31:14] =='0 ; }
else {random_wr_data[i][31:9]=='0 ; random_wr_data[i][7:4]=='0;}
function new(string name="seq" );
super.new(name);
virtual task body();
success_rand= std::randomize(random_wr_data);
`uvm_info("seq",$sformatf("randomization =%d",success_rand),UVM_NONE);
for (int i=0;i<=16;i++)begin
wr_addr = wr_addr + 'h4;
do_write(wr_addr, random_wr_data[i]);
`uvm_info(get_type_name(), $sformatf("Write Address:%0h, Data=[%0h]",wr_addr,random_wr_data[i]),UVM_NONE)
do_read(wr_addr, ccu_rd_data[i]);
`uvm_info(get_type_name(), $sformatf("Read Address:%0h, Data=[%0h]",wr_addr,rd_data[i]),UVM_NONE)
endtask// body
can anyone please help?
thank you
cgales
March 2, 2023, 8:27pm
2
Several issues:
When you call std::randomize() on a variable, there are no constraints applied unless you pass them on the randomize() call:
success_rand=std::randomize(random_wr_data) with {constraint...};
You can randomize the entire class instance to utilize the constraint C1 with:
if (!this.randomize()) `uvm_error("seq", "Randomization failed");
To enable the class randomization, you need to add ‘rand’ to random_wr_data .
Here is a working example:
import uvm_pkg::*;
`include "uvm_macros.svh"
`uvm_object_utils( seq1 )
bit[23:0] wr_addr ;
rand int random_wr_data[];
int rd_data[];
constraint C1 {
foreach(random_wr_data[i]) {
if (i==0) { random_wr_data[i][31:12] =='0 ; random_wr_data[i][0]=='b0; }
super.new(name);
task body();
`uvm_info("seq",$sformatf("Array has %d elements", random_wr_data.size()), UVM_NONE);
// do_write(wr_addr, random_wr_data[i]);
// do_read(wr_addr, ccu_rd_data[i]);
endtask// body
class test extends uvm_test();
`uvm_component_utils(test)
function new(string name="test", uvm_component parent = null);
super.new(name,parent);
seq1 my_seq;
my_seq = seq1::type_id::create("my_seq");
my_seq.start(null);
module top();
run_test("test");
/systemverilog]
