let’s say I have 3 variables a,b, and c in my item class. I want to solve c based on values of a and b. But I also provide an inline constraint when randomizing the item
class item;
rand int a, b,c;
constraint cst{
solve a before c;
solve b before c;
c == a+b;
class some_other_class;
item.randomize with {
c < 8;
In the above code will the simulator keep changing the values of a and b to satisfy the inline condition of a+b<8 ?
I made a mistake in my previous code. Here is the code
class item;
rand unsigned int a, b,c, d;
constraint cst{
solve d before b;
solve a before c;
solve b before c;
(d==0) -> b == 40;
c == a+b;
constraint cst_d{
d dist{
0:=10,
1:=80
c < 8;
The constraint c < 0 can never be true since c is unsigned. You would get the same constraint failure had you added that constraint directly into the class item.
