I’m having the following simple class where in I need the arr elements such that the sum of each row as well as sum of each col is equal to the total elements.
the num of elements determine the shape (rows/cols) of the 2d arr.
class arr_2d_size;
rand int arr[][], arr_t[][];
rand int num_elem;
rand int cols, rows;
constraint size_c{
(cols * rows) == num_elem;
rows == cols; // need this so that the sum constraints work on both rows and cols
cols > 0;
rows > 0;
//actual arr
arr.size == rows;
foreach(arr[i])
arr[i].size == cols;
foreach(arr[i,j]){
arr[i][j] inside {[0:num_elem*num_elem]}; // only positive values
//helper arr
arr_t.size == cols;
foreach(arr_t[i])
arr_t[i].size == rows;
constraint row_sum_c{
foreach(arr[i])
arr[i].sum == num_elem;
constraint trans_c{
foreach(arr_t[i,j])
arr_t[i][j] == arr[j][i];
constraint col_sum_c{
foreach(arr_t[i])
arr_t[i].sum == num_elem;
module arr_elem;
arr_2d_size a = new();
for(int i = 0 ; i < 10; i ++) begin
if(! a.randomize() with {num_elem == 4;}) // gives constraint solver error - why? if rows==cols is not provided
$error("failed with num_elem == 4 ");
//a.randomize() with {rows == 3; cols == 3;}; // this works
for num_elem == 4, the possible solutions are one of the following …
‘{’{4, 0} , '{0, 4} }
‘{’{1, 3} , '{3, 1} }
‘{’{0, 4} , '{4, 0} }
‘{’{2, 2} , '{2, 2} }
‘{’{3, 1} , '{1, 3} }
My question is … when I provide the constraint rows==cols, it always picks up one of the above solutions. but when this constraint is not used, and num_elem == 4, we can have the following combinations for rows and cols
rows = 1, cols = 4 (a)
rows = 2, cols = 2 (b)
rows = 4, cols = 1 (c)
and when the solver picks a/c, it will fail.
When I run this for say 10 times, without the above constraint (rows == cols), I see it fails about 60% of the time irrespective of the simulator I use (from edaplayground)
since option (b) is possible, should the constraint solver not provide a solution based on this always? why does it fail? Is there any requirement on the constraint solver to provide a case when it is available rather than fail?
