I am getting unexpected output for this randopmised distribution , -please help why this is like that
module random_dist;
class rd;
rand bit [31:0]a;
constraint c{ a dist{4:=5, 2:=5};};
rd obj;
obj = new;
repeat(10)begin
obj.randomize();
$display(obj.a);
and the output is
# 2
# 2
# 2
# 2
# 2
# 4
# 4
# 2
# 4
# 2
In reply to rakesh reddy:
i am not getting 5 number of 4’s and 5 number of 2’s can any one tell me my mistake in this code
Your distribution constraint says for each randomization, the odds of choosing a 4 or 2 are 50%/50%. This is the same as flipping a coin 10 times in a row and expecting to see the same side exactly 5 times. The odd of that happening are quite low (10 choose 5)/2**10 = ~25%).
Dave, then what is the use of dist operator for getting the randmisation distribution
Your distribution can only bee seen with longer tests. As you increase the number of randomizations, the results will approach you distribution. However, the chances of the results giving you exactly your distribution decreases.
