Hi
In my TB I make 2 instance of module called “dcg_top”:
logic[0:1] cfi_clkreq;
cfi_clkreq = '0;
#1us;
cfi_clkreq = 2'b11;
#1us;
cfi_clkreq = 2'b00;
dcg_top #(
)cfi0(
.clk_req('{cfi_clkreq[0]})
dcg_top #(
)cfi1(
.clk_req('{cfi_clkreq[1]})
Each instance gets one bit of cfi_clkreq array as input.
when clk_rek changed from 0 to 1 this task is called:
task clock_vc_dcg::wait_before_clk_ack();
randcase
20: async_delay_ps(20, 1);
35: async_delay_ps(2500, 20);
15: async_delay_ps(10000, 2500);
15: async_delay_ps(30000, 10000);
10: async_delay_ps(30000, 10000);
8 : async_delay_ps(100000, 30000);
2 : async_delay_ps(200000, 100000);
endcase
endtask : wait_before_clk_ack
As you can see in my TB I change clk_req from 00 to 11 so this task should be called twice, in the two instance.
My problem is that in the both task call, the randcase returns the same value, even it called from separate instance.
How can I fix it? I want randcase to return different value in each call.
thanks!
