Hi all ,
LRM 18.8 :: The syntax for the rand_mode() method is as follows:
task object[.random_variable]::rand_mode( bit on_off );
or
function int object.random_variable::rand_mode();
The object is any expression that yields the object handle in which the random variable is defined.
The random_variable is the name of the random variable to which the operation is applied.
For unpacked array variables, random_variable can specify individual elements using the corresponding
index. Omitting the index results in all the elements of the array being affected by the call."
The function form of rand_mode() only accepts singular variables; thus, if the specified variable is an
unpacked array, a single element shall be selected via its index
**I am confused with the last line in LRM .
It says I can’t call rand_mode( 0 ) on a random unpacked property .**
However when I try following code ::
class Main ;
rand bit [1:0] A [2] ;
Main m ;
m = new() ;
if ( m.randomize() )
$display("Success with %p",m);
$display("Fails");
m.A.rand_mode(0) ; // [a1] Legal ??
$display("Fails");
m.A[1].rand_mode(1) ; // [a2] Legal ??
$display("Fails");
I Observe that [a1] N [a2] both work !!
i.e 1 possible Output is ::
**Success with '{A:'{'h3, 'h2}}
Success with '{A:'{'h3, 'h1}}**
[Q] Is my interpretation about the last line wrong OR are simulators violating the LRM ??
