Queues of Dynamic Arrays
Are queues of dynamic arrays allowed in either SystemVerilog or VMM? For example:
logic [7:0] Qda [$];
if that’s allowed, how do I initialize the dimension of the dynamic arrays at run-time? Would this still work:
Qda = new[10];
and lastly, suppose I have an dynamic array of the same size:
logic [7:0] DA;
DA = new[10];
how would I push_back this into Qda, essentially adding one more element to the queue? Thanks in advance!
In reply to jin_hsueh:
Yes you can have queues of dynamic arrays in SystemVerilog, but remember that you are declaring an array of an array, not really a multidimensional array. The difference is each dynamic array element in the queue can have a different dynamic array size.
   logic [7:0] Qda[$] []; // this is a Queue -> of dynamic arrays -> of logic [7:0]
   logic [7:0] DA[]={1,2,3};
      Qda = '{10{ {} }}; // initializes a Queue of 10 empty dynamic arrays
      Qda.push_back(DA); // pushes the eleventh Queue element by copying the DA {1,2,3}
      $display("%p",Qda);
That works. Thank you very much!
In reply to jin17:
Now I’m running into an issue trying to assign a slice of the array above. Instead of
logic [7:0] DA;
I had:
logic [15:0] DA2;
But the following assignment would generate a compile error:
DA2[11:0] = Qda.pop_front();
Error- Incompatible complex type
Incompatible complex type assignment
Type of source expression is incompatible with type of target expression.
Mismatching types cannot be used in assignments, initializations and
instantiations. The type of the target is ‘logic[15:0][]', while the type of the source is 'logic[7:0]’.
Source Expression: this.Qda.pop_front
My intention is to pop the first dynamic array off Qda, and assign it to DA2. But since the packed dimensions are different, I want to put each byte of Qda’s lowest-indexed dynamic array into the LSB’s of each word of DA2. What’s the best way to accomplish this? Thanks again in advance.
In reply to jin17:
Assignments only work with contiguous sets of bits. You will need to pop into an intermediate dynamic array variable, and then use a foreach loop.
   logic [7:0] temp_da[];
   logic [15:0] DA2[];
      temp_da = Qda.pop_front();
      DA2 = new[temp_da.size];
      foreach(DA2[ii]) DA2[ii] = temp_da[ii];
      $display("%p",DA2);
You are good. Thanks again!
Dave :
I would like to confirm it
logic [7:0] Qda[] []; this is a**Queue -> of dynamic arrays -> of logic [7:0]** ? logic [7:0] Qda[] [];
this is adynamic array → of Q → of logic [7:0] ?
In reply to VE:
Try using
.push_back()
to confirm.
